Hi all!
When creating turnout reports, the "TurnoutPoint" representing shunt limit (or fouling point) is displayed as "53".
Is there any way to change this to something more descriptive?
<?xml version="1.0" encoding="UTF-8"?> <xsl:stylesheet version="1.1" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:inr="http://mycompany.com/mynamespace"> <xsl:include href="../format.xsl"/> <xsl:param name="xslRootDirectory" select="inr:xslRootDirectory"/> <xsl:template match="/"> <xsl:variable name="gridOut" select="inr:SetGridOut(number(InRoads/@outputGridScaleFactor))"/> <html> <head> <link rel="stylesheet" type="text/css" href="{$xslRootDirectory}/_Themes/engineer/theme.css"/> <title lang="en">Shunt Limits Report</title> </head> <body> <xsl:choose> <xsl:when test="$xslShowHelp = 'true'"> <xsl:call-template name="StyleSheetHelp"/> </xsl:when> <xsl:otherwise> <xsl:for-each select="InRoads"> <center> <h2 lang="en">Shunt Limits Report</h2> <p lang="en"> Report Created:  <xsl:value-of select="inr:date()"/> <br/> Time:  <xsl:value-of select="inr:time()"/> </p> </center> <xsl:for-each select="GeometryProject"> <table class="margin" cellpadding="2" width="90%"> <tbody> <tr> <th align="right" lang="en">Project:  </th> <td align="left" colspan="2"> <xsl:value-of select="@name"/> </td> </tr> <tr> <th align="right" lang="en">Description:  </th> <td align="left" colspan="2"> <xsl:value-of select="@description"/> </td> </tr> <tr> <th align="right" lang="en" style="font-size: 80%">Input Grid Factor:  </th> <td align="left" style="font-size: 80%"> <xsl:value-of select="../@inputGridScaleFactor"/> </td> <td align="right" lang="en" style="font-size: 80%"> <strong>Note:  </strong>All units in this report are in <xsl:if test="//@linearUnits = 'Imperial'">feet</xsl:if> <xsl:if test="//@linearUnits = 'Metric'">meters</xsl:if> unless specified otherwise. </td> </tr> </tbody> </table> <hr/> <xsl:for-each select="Turnout"> <table class="margin" cellpadding="1" width="90%"> <tbody> <tr> <td align="left" colspan="6" lang="en"> <strong>Turnout:  </strong> <xsl:value-of select="@name"/> <xsl:text> </xsl:text> <xsl:value-of select="@description"/> (<xsl:value-of select="@style"/>) </td> </tr> <xsl:apply-templates/> </tbody> </table> <hr/> </xsl:for-each> </xsl:for-each> </xsl:for-each> </xsl:otherwise> </xsl:choose> </body> </html> </xsl:template> <xsl:template match="HorizontalLine"> <xsl:if test="position() = 1 or preceding-sibling::*[1][name() = 'TurnoutBranchGeometry']"> <tr> <th align="left" colspan="2" lang="en" valign="bottom">Element Type</th> <th align="right" lang="en" valign="bottom">Length</th> <th align="right" lang="en" valign="bottom">Start Radius</th> <th align="right" lang="en" valign="bottom">End Radius</th> <th align="right" lang="en" valign="bottom">Start Northing</th> <th align="right" lang="en" valign="bottom">Start Easting</th> </tr> </xsl:if> <tr> <td align="left" colspan="2" lang="en">Linear</td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@length), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(0.), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(0.), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:northingFormat(number(Start/@northing), $xslNorthingPrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:eastingFormat(number(Start/@easting), $xslEastingPrecision)"/> </td> </tr> </xsl:template> <xsl:template match="HorizontalCircle"> <xsl:if test="position() = 1 or preceding-sibling::*[1][name() = 'TurnoutBranchGeometry']"> <tr> <th align="left" colspan="2" lang="en" valign="bottom">Element Type</th> <th align="right" lang="en" valign="bottom">Length</th> <th align="right" lang="en" valign="bottom">Start Radius</th> <th align="right" lang="en" valign="bottom">End Radius</th> <th align="right" lang="en" valign="bottom">Start Northing</th> <th align="right" lang="en" valign="bottom">Start Easting</th> </tr> </xsl:if> <tr> <td align="left" colspan="2" lang="en">Circular</td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@length), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@radius), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@radius), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:northingFormat(number(Start/@northing), $xslNorthingPrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:eastingFormat(number(Start/@easting), $xslEastingPrecision)"/> </td> </tr> </xsl:template> <xsl:template match="HorizontalSpiral"> <xsl:if test="position() = 1 or preceding-sibling::*[1][name() = 'TurnoutBranchGeometry']"> <tr> <th align="left" colspan="2" lang="en" valign="bottom">Element Type</th> <th align="right" lang="en" valign="bottom">Length</th> <th align="right" lang="en" valign="bottom">Start Radius</th> <th align="right" lang="en" valign="bottom">End Radius</th> <th align="right" lang="en" valign="bottom">Start Northing</th> <th align="right" lang="en" valign="bottom">Start Easting</th> </tr> </xsl:if> <tr> <td align="left" colspan="2"> <xsl:value-of select="@type"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@length), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@startRadius), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(@endRadius), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:northingFormat(number(Start/@northing), $xslNorthingPrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:eastingFormat(number(Start/@easting), $xslEastingPrecision)"/> </td> </tr> </xsl:template> <xsl:template match="TurnoutPoint"> <xsl:if test="preceding-sibling::*[1][name() != 'TurnoutPoint']"> <tr> <th align="left" lang="en" valign="bottom">Point Name</th> <th align="left" lang="en" valign="bottom">Mainline<br/>Alignment</th> <th align="left" lang="en" valign="bottom">Style</th> <th align="right" lang="en" valign="bottom">Station</th> <th align="right" lang="en" valign="bottom">Offset</th> <th align="right" lang="en" valign="bottom">Northing</th> <th align="right" lang="en" valign="bottom">Easting</th> </tr> </xsl:if> <tr> <xsl:choose> <xsl:when test="GeometryPoint/@name = '.1'"> <td>.1</td> </xsl:when> <xsl:when test="GeometryPoint/@name = '.0'"> <td>.0</td> </xsl:when> <xsl:when test="GeometryPoint/@name = '.2'"> <td>.2</td> </xsl:when> <xsl:when test="GeometryPoint/@name = '.3'"> <td>.3</td> </xsl:when> <xsl:when test="GeometryPoint/@name = '53'"> <td>Shunt Point</td> </xsl:when> <xsl:otherwise> <xsl:value-of select="GeometryPoint/@name"/> </xsl:otherwise> </xsl:choose> <td align="left"> <xsl:value-of select="@mainlineAlignment"/> </td> <td align="left"> <xsl:value-of select="GeometryPoint/@style"/> </td> <td align="right" nowrap="nowrap"> <xsl:value-of select="inr:stationFormat(number(GeometryPoint/station/@externalStation), $xslStationFormat,$xslStationPrecision, string(GeometryPoint/station/@externalStationName))"/> </td> <td align="right"> <xsl:value-of select="inr:distanceFormat(number(GeometryPoint/@offset), $xslDistancePrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:northingFormat(number(GeometryPoint/@northing), $xslNorthingPrecision)"/> </td> <td align="right"> <xsl:value-of select="inr:eastingFormat(number(GeometryPoint/@easting), $xslEastingPrecision)"/> </td> </tr> </xsl:template> <xsl:template name="StyleSheetHelp"> <div class="section1"> <h4 lang="en">Notes</h4> <p class="normal1" lang="en"> Your active geometry project must have at least one turnout definition. </p> <p class="normal1"> You must select at least one turnout in the <em>Geometry > Turnouts > Reports</em> command. </p> <h4 lang="en">Tips</h4> <p class="normal1" lang="en"> To access the <em>Turnouts</em> commands, select the <em>Tools > Application Add-Ins</em> command and toggle on the <em>Turnouts Add-In</em>. </p> <p class="small" lang="en"> <em>© 2006 Bentley Systems, Inc</em> </p> </div> </xsl:template> </xsl:stylesheet>
In the attached look for the following:
</xsl:when>
Change the wording SHUNT POINT to whatever you want. Remove the .txt from the file name and place it in the appropriate report folder.
R. W. Bradshaw
Answer Verified By: EBlach
