Hello!
This problem occurs very often. Typically when I use "project to surface".
If I turn of my control points of cant and alignment, the template goes down, on the level of the wrong working element
I assume that the template is placed from the origin point, when the control points are turned off.
If I place the Origin point the template basically will work OK (from cant there will be some glitches) . But for some reason i cant modify this point. When i set origin somewhere else, and save the template, in the next opening the origin point is on the old place!
Is there a cure for this or i need to stop using project to surface :D
Greetings,
A.M.
I have managed to change the origin point but the problem persist. -- I saw that the template is located by its coordinate system: http://prntscr.com/ck428t But how I can place a point in exactly 0,0 of this coordinates ?
(BRT V08.11.07.685, on MS, SS 2)
