Respected Sir,
how to import file in Bentley powe rail track V8i series4.
I have three files
1. ALG FILE
2 .DTM FILE
3. XIN FILE
Thank you Sir,
Prashant Sharma
Prashantcivil.sharma@gmail.com
Hi Prsahant, Please use the civil or openrail forum, where you will find help for these Bentley Application.
ALG, DTM, and XIN are files from Bentley InRoads and derivate products.
Are you trained with Bentley Power Rail Track?
Look: http://communities.bentley.com/products/road___site_design/
http://communities.bentley.com/products/rail_design/
Frank
All these files are Rail Track files so they don't have to be imported but just opened through the Rail Track Files open command. The question is what do you want to do with the content ? Then it is when some training can help.
In Power Rail Track SS4 you can do everything you did in previous version in the same way except Corridor modelling and Create Cross section. Roadway Designer is no more available.
It means that if you want to do a corridor you must use Civil tools (new tools from Civil Tools task bar).
