I'm often in a situation that I need to moved a PI-point by following one of the two tangent-directions. It would be perfect, if I could f.ex. push the <ctrl> key down while moving the point. Is there a way to achieve that in the current PowerCivil / Power RailTrack versions, maybe in future? This function would be very welcome for both horizontal and vertical editing.
Best regards,
LiPeng from Denmark.
(BRT V08.11.07.685, on MS, SS 2)
A bit late, but hope it can help or give some idea
Answer Verified By: LiPeng
If using Civil Geometry (Rail Track SS4) it is easier
