After designing horizontal alignment with 100 curves, i created cant alignment as a child under horizontal alignment.
Then i clicked Define all option and used equilibrium equation method. Many of the curves i defined cant by editing speed and applied cant manually.
And finalised all the 100 curves.
Here my Problem is if i change the transition length or radius of the one curve, the cardinal point location of all subsequent curves are getting changed.
For example if i change the curve parameters at Curve number 3, the cardinal point location from curve 3 to curve 100 are getting changed.
I can Redefine cant alignment with define all option. But i need to change again all the curves wherever i made the changes manually.
Can anyone sort out my problem?
(BRT V08.11.07.685, on MS, SS 2)
Answer Verified By: RAJENDRA
