Wrong importing of regression from alignments
Hello!
I have 4 overlapping alignments, with regression points only. I tried to import all regression points in one alignment. But there occurs some bug:
You can see when i visualize the original point its on the correct place, but the point imported in the merged alignment is placed down:
Is this happened to some of you? And how to fix it?
