my alignment has 4 curves and i have applied cant as follows
1-curve (RH)-----+ve cant
2-curve(LH)------ -ve cant (Cant direction same as on curve 1 but because curve direction is different from previous on so in BRT i input it as -ve cant)
3-same as No. 2
4-Same as No. 1
So CANT DIRECTION remain same i.e LHR
but with this CANT the new rails created have problems, as the CANT changes the low rail in profile swaps from LH RH (see screen shot attached )
white line is CL, Yellow = LHR and Green = RHR
