hi ,
I am using MX road (XM version) and want to get Mass Haul diagrams. I went through HELP section but was unable to get info abt how exactly it is done. I did try this command given in HELP section in line mode but I am getting this error msg tht "Model does not exist" even after I created all the necessary models. So if anybody is having correct command for linemode please help. Also i want to ask where is this "MASS HAUL ANALYSIS" found in MX tools?
Kshitij
I have some examples of INput to create a Mass Haul Diagram.
If you want to contact me at simon.pegg@bentley.com I cna let you have them.
REgards
Simon Pegg
Bentley Civil TSG
Dear Simon,
Can I have a copy from thoses input files.
Regards, Ahmed Hazem
You can find example files in the tutorial folder, typically: C:\Program Files\....\ MX \ MfW \ xx_tut
The input files are called "simp105.inp" and "Simp105 in NTA.inp" (for non-tangential projects).
I've also zipped and attached them.
Best Regards
Wolfgang
Dear Sir,
Thanks for your reply, but any avilable help about the content of that txt files.
Do Bently have a plan to add mass haul to GUI???.
Ahmed Hazem
