InRoads V8i Template Transition - GEOPAK | InRoads | MX | OpenRoads Forum - GEOPAK | InRoads | MX | OpenRoads - Bentley Communities
I am trying to transition between two templates. My transition is dark blue in the modeler and when I edit  the transition, I remove one point constraint and the edit transition midpoint works fine from the start to end. When I return to the modeler, the transition area does not reflect what it should do.
I am modeling some beam guard, bull nose, and I need to transition from a 4:1 to a 10:1 and have two templates indicating as such.
I've attached my alg, ird, xin, dtm and itl. I don't know if it is my templates or if I am editing the transitions incorrectly. Any help would be appreciated.
Bill
MS 8.11.07.443
IR 8.11.07.494
Post.zip
2 Replies (Most Recent Reply)
  • The point controls appear to be causing an issue with the transition. Bentley support can take a look at the exact cause.  I'd suggest using a parametric constraint for a transition like this instead.  See attached:
  • In reply to Chris Dry:
    Thanks for your reply. I wil try the parametric constraints.
    MS 8.11.07.443
    IR 8.11.07.494
^ Go to first post
