Is there some software like Plexearth tool for Autocad for importing color images from Google Earth also for Microstation.
Thanks, Petr.
If you have v8i or later you have the Capture Google Earth Image tool. See the screen capture and refer to the help file for details.
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
However, Google only allows gray-scale images to be imported.
I know about the the Google image capture tool, but I had on my mind some application like see the link: www.plexscape.com/plexearth.aspx wich allows you to get color images from Google earth into Microstation right into coordinates and these image are attached to a drawing as rasters.
Petr,
You get the google earth DTM-Data as well with the microstation google functions
Frank
I know that I can get dtm data with microstation google functions, but I would like to get color raster images from google to microstation.
Regards, Petr.
