I have three microstation programs: inroads, descartes, and geopak. I find myself switching back and forth between the three programs to get the different tools I need. Is there anyway to combine all of these into one interface and have all the tools at the ready?
Do you mean you have three different versions of MicroStation in order to run InRoads, Descartes and GeoPak?
If all those programs are V8i SELECTSeries programs you should be able to install all those on one MicroStation. Just keep the latest MicroStation you have and flush the other MicroStation.
HTH,
Mathieu
Yes I guess what I'm asking is how to incorporate them all into one version of microstation. Any tips on how to make that happen?
Bentley support states that this is not possible. Although I feel like it is somehow or at least should be.
Descartes can run with InRoads or GEOPAK, all you have to do is choose the Descartes user workspace in MicroStation when launching InRoads or GEOPAK.
InRoads and GEOPAK can not run at the same time because they load many commands into MicroStation that will act differently based on which one is loaded. Therefore, only one set of tools needs to load into MicroStation when InRoads or GEOPAK is kicked off.
Answer Verified By: Kurt Rasmussen
