Prostructures (Select series 5) and Navisworks 2012/13 not compatible? - Subforum ProStructures - ProStructures - Bentley Communities
Before installing Select series 5, Navisworks (2012 and 2013) read Prostructures objects without problem. Now I can't view those items at all.
What things should I be trying to get this working again?
5 Replies (Most Recent Reply)
  • In reply to Michael Kornbrekke:
    Navisworks caches the dwg file to a nwc file and then uses only the nwc file. You must remove the nwc file.
    Then Navisworks uses the prostructures.dbx to open the dwg and to cache it.
    I have Navisworks 13 but I forced it to use the 18.2 dbx Loader. Dwg Loader Version is set to 2012.
    Can be set with Global options.
    Reason is:
    AutoCAD 2013 needs a Service Pack 1.1 to load ProStructures Dwgs.
    Same for the RealDwg 2013 as I can see with Bentley MicroStation SS3.
    I guess a Service Pack 1.1 for NavisWorks 2013 will be offered by Autodesk later.
    The AutoCAD object dbx entry for Pro_Stahl_App points to the Navisworks folder.
    I have the AutoCAD objectenabler (objectdbx) key and the Navisworks objectdbx key set up.
    Please look at my screenshots and try to reproduce.
  • In reply to Johannes Michalowsky:
    Thankyou for the reply. I am having trouble seeing the screenshots (they are too small), but I will try to work through it as best I can. We are running AutoCAD 2012, I am not sure if that will make a difference.
    I know this is quite old, but can you send the original pictures to me at jvandyke<at>
    I am trying everything possible to get the steel to render in NavisWorks 2014 and any help would be appreciated.
    Thank you,
  • In reply to Jon VanDyke:
    Whoever needs the Enablers for Navisworks.
    The Enablers are avail now directly with all Settings done automatically by a Setup routine.
    Just send me a Mail as they are not yet available on SELECT.
^ Go to first post
