ISM file creation
Structural
This is where you can find and contribute to discussions, ideas, and other information about Bentley Structural Analysis and Design and Structural Drafting and Detailing products.
ISM file creation
  • rated by 0 members
  • This post has 1 Reply |
  • 1 Follower
  • From Revit, when you "Create the repository", the Structural Synchronizer window will launch as you noted. In this viewer you need to hit the [Update Repository] button to complete the action.
  • Using revit 2010 I'm creating aN ISM repository.
    After mapping the members the file opens within the synchroniser window within approx 2 minutes and looks pretty good.
    the question is how can i save this file.
    Expanding the window shows that although the task bar has reached 100% it says it's still writing the repository.
    You will notice that this is still the case 2hrs and 22 minutes later.
    is something failing to happen? or am I misunderstanding the process
    How can I save the .ism.dgn file to allow it to be opened across the network by another office in a different time zone to create a file in RAM or Staad?
    Many thanks for any help
Page 1 of 1 (2 items)
