Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
RAM | STAAD | ADINA
RAM | STAAD Forum
slip resistant connection in RAM
Sign In
State
Suggested Answer
Replies
Answers
1 answer
Subscribers
114 subscribers
Views
Users
0 members are here
slip resistant
Eurocode
Offline
Vishal Girase
over 7 years ago
Is it possible to define and design slip resistant connection in staad according to eurocode?
0
Seth Guthrie
Fri, Dec 9 2016 11:54 AM
What kind of connection specifically did you have in mind? With STAAD.pro SELECTseries 6 we can perform connection design to the Eurocode (EN 1993) and we offer a variety of joints and bolt options, including HSFG bolts if that's all you need.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Vishal Girase
Sat, Dec 10 2016 5:24 AM
in reply to
Seth Guthrie
1) Oh yes i will have tick the check for slip resistance in left column.
Now I want design beam to beam splice joint
In addition to ordinary bearing type joint i will have to add
"check for slip resistance" & HSFG bold grade instead of M16G_8.8 (lets say).
Am i right?
But still i found warning
2) Bolt slip class does not match slip resistance recommendations. Why?
Also for HSFG bolts can have 2 property class 8.8 and 10.9
3) So which property class is used when we select HSFG bolt?
4) Also when i use 4.6 property class for fin plate connection supporting beam web it give warning
Unsuitable bolt grade for recommended detailing.??
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
rtully14
Mon, Dec 12 2016 9:40 AM
With regard to your fourth query SCI Publication P358 recommends on page 109, section 5.3, that 8.8 bolts are to be used. I will look at the requirements for HSFG bolts and get back to you.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
rtully14
Mon, Dec 12 2016 10:56 AM
Can you please upload your file in order that i can review the issues?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
