Dear prosteel users,
I am facing following problem at the time of starting work on Prosteel.
Reply if know solution on this.
Command: ; error: ARXLOAD failed
Command: Command: at_ContextMenu_LoadDrawingPreferences ; error: no function definition: C:AT_DRAWINGPREFERENCES_LOAD
Command: Command: AT_CONTEXTMENU_LOADDRAWINGPREFERENCES ; error: no function definition: C:AT_DRAWINGPREFERENCES_LOAD
Command: Command: at_ContextMenu_LoadProjectPreferences ; error: no function definition: C:AT_PROJECTPREFERENCES_LOAD
VP
