This question brings up many excellent points about modeling and setting design parameters in STAAD.Pro. Refer to the image below:
Assume that this structure has metal wall panels that will transmit wind loads to the steel framing, but will be considered ineffective in resisting lateral loads through shear wall action. One approach to modeling this condition would be to create Wind Definitions and Wind Load Cases, and allow STAAD.Pro to automatically generate wind loads, which will we applied to the nodes of the model. Another approach would be to create a mesh of plates that span between the girts, assign the IGNORE STIFFNESS specification to those plates, and apply plate pressure loads to the plates to represent the wind pressures. The IGNORE STIFFNESS specification will instruct the program to consider the plates ONLY for the purpose of distributing the wind pressures to the supporting framing, but to ignore the plates when the stiffness matrix is formed, so the plates will not provide any resistance when the model is analyzed.
Regardless of the method used to apply the wind loads, there will always be the issue of verifying/assigning the appropriate bracing parameters when it comes to design. For example, in the model illustrated above, we might want to indicate that:
All of these design decisions are indicated by the assignment of design parameters like Ky, Ly, Kz, Lz, UNT, UNB, etc.
Chris
Dear Sir,
Will you please send me that sample 3D design in .std format?
Rajkumar
I have attached a sample model.
Thank you very much to all of you.
Mushtaq Ahmad
Currently I am working on Dissertation project related to Multistory Residential Steel Building Design using Staad Pro. so i want to know more about particular steel section details which are used in this type of design and how it will design connection & floors . so i want some links from which i can get this details or access to journals or books. Can you suggest me some good books related this topic or links
