Dear all
I have attached picture to show the example of BMD graph diagram from anonymous.I try to do it in any solution (such as physical beam but not show scale of moment on y-axis) but i can't.
Thanks for your advance
I think the attached image shows a sample of what you are looking to achieve. Here's how I created it:
1. In post processing mode, go to Beam tab. Forces subtab will be active by default. Mz diagram will be displayed by default.
2. Set Active Load dropdown list to Envelope.
3. Click Results > View Value. On the Beam Results tab, select Maximum in the Bending category.
4. Adjust scale as necessary.
Chris
Thank you for your kindness chris.In my opinion your method for show continuous beam is enough but if possible I need to know how to create result like my attached picture.
regards
