Designing Rectangular Columns in STAAD Pro - RAM | STAAD Forum - RAM | STAAD - Bentley Communities
I noticed that when we design a rectangular column, STAAD Pro always arrange the reinforcements as equal number on each face ? I ask the instructor who teach us at Bentley and he didnt have an answer.
5 Replies (Most Recent Reply)
  • Not sure which code you are referring to. But for most codes, STAAD designs columns by placing equal number of bars on all 4 faces. For some codes like the Indian code, there is a parameter to specify if the bars should be just on 2 faces.
  • In reply to SKLose:
    ACI-318-05 Code.I think that whatever you do, STAAD Pro can not handle unequal arrangement of bars.
    check this output file:
                *           STAAD.Pro V8i SELECTseries1                *
                *           Version  20.07.06.35                                    *
                *           Proprietary Program of                                 *
                *           Bentley Systems, Inc.                                   *
                *           Date=    OCT  3, 2010                                   *
                *           Time=    20:34:35                                          *
                *      USER ID: ***************************               *
        1. STAAD SPACE
        2. START JOB INFORMATION
        3. ENGINEER DATE 03-OCT-10
        4. END JOB INFORMATION
        5. INPUT WIDTH 79
        6. UNIT FEET KIP
        7. JOINT COORDINATES
        8. 1 0 0 0; 2 0 10 0
        9. MEMBER INCIDENCES
       10. 1 1 2
       11. DEFINE MATERIAL START
       12. ISOTROPIC CONCRETE
       13. E 453600
       14. POISSON 0.17
       15. DENSITY 0.150336
       16. ALPHA 5E-006
       17. DAMP 0.05
       18. END DEFINE MATERIAL
       19. MEMBER PROPERTY
       20. 1 PRIS YD 3.28084 ZD 0.984252
       21. CONSTANTS
       22. MATERIAL CONCRETE ALL
       23. SUPPORTS
       24. 1 FIXED
       25. LOAD 1 LOADTYPE NONE  TITLE LOAD CASE 1
       26. JOINT LOAD
       27. 2 MX 100
       28. PERFORM ANALYSIS
       STAAD SPACE                                              -- PAGE NO.    2
               P R O B L E M   S T A T I S T I C S
        NUMBER OF JOINTS/MEMBER+ELEMENTS/SUPPORTS =     2/     1/     1
              SOLVER USED IS THE OUT-OF-CORE BASIC SOLVER
        ORIGINAL/FINAL BAND-WIDTH=     1/     1/      6 DOF
        TOTAL PRIMARY LOAD CASES =    1, TOTAL DEGREES OF FREEDOM =      6
        SIZE OF STIFFNESS MATRIX =        1 DOUBLE  KILO-WORDS
        REQRD/AVAIL. DISK SPACE  =     12.0/ 327276.8 MB
       29. START CONCRETE DESIGN
       30. CODE ACI
       31. MAXMAIN 10 ALL
       32. DESIGN COLUMN ALL
       STAAD SPACE                                              -- PAGE NO.    3
           COLUMN  NO.     1  DESIGN PER ACI 318-05 - AXIAL + BENDING
      FY - 60000  FC - 4000 PSI,  RECT SIZE - 11.81 X 39.37 INCHES, TIED
              AREA OF STEEL REQUIRED =   6.929  SQ. IN.
      BAR CONFIGURATION       REINF PCT.   LOAD   LOCATION   PHI
       12 - NUMBER  7           1.548        1      END     0.650
      (PROVIDE EQUAL NUMBER OF BARS ON EACH FACE)                 ???????
      TIE BAR NUMBER    4 SPACING  11.81 IN
      ********************END OF COLUMN DESIGN RESULTS********************
       33. END CONCRETE DESIGN
       34. FINISH
  • In reply to Ahmed Shakir:
    For column design per the ACI code, STAAD offers only an arrangement that involves equal bars on all 4 faces.
  • In reply to Geeky biswa:
    I think this should be written beside the message :
    by saying:
    Note that: For current release, STAAD CAN ONLY ARRANGE COLUMNS BARS AS EQUAL NUMBER ON ALL 4 FACES.
    in that way when STAAD somtimes said that there is no possible arrangemnet for bars, that not necessarlly lead to wrong design so one should increase the column size but one should check other arrangments that STAAD can not handle.
    Mr. Ahmed Sh is right. Some change in Staad make engineer happier ever after, I think.
^ Go to first post
