Good day,
Can staad pro select the members based on strength AND serviceability criteria?
This basic feature has been discussed numerous times so I am wondering were there any improvements in the latest release.
Aleks
For AISC 360-10, here is the procedure.
Let us say that the load list for steel design (deflection checks and strength checks) is 101 to 185
Also, let us assume that load cases 101 to 120 are the ones for deflection checks and the remaining are for strength checks.
The load cases that are required for deflection checks should be included in a load envelope that is defined as a ‘Serviceability’ case:-
. DEFINE ENVELOPE
. (load case and combination numbers) ENVELOPE (envelope number) TYPE SERVICEABILITY
. END DEFINE ENVELOPE
During code checking per AISC 360-10, cases 101 to 120 will be used only for deflection checks, the remaining will be used for strength checks.
Regarding the crashes you are experiencing, try using the latest build - 20.07.09.31. The number of reported cases in this new version is far less than in the previous builds.
Thank you - but I am asking about member selection not code check.
What I would like is that STAAD determines what is the governing case (strength or serviceability) and select the appropriate member. Strength should be based on ULS envelope and serviceability on SLS envelope.
Is proposed solution applicable to member selection?
Yes, the method I suggested is applicable for member selection too.
Ok - here is the simple example:
STAAD PLANE
START JOB INFORMATION
ENGINEER DATE 29-Apr-13
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 0; 2 8 0 0;
MEMBER INCIDENCES
1 1 2;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
END DEFINE MATERIAL
MEMBER PROPERTY CANADIAN
1 TABLE ST W130X24
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 PINNED
2 FIXED BUT FX MY MZ
LOAD 1 LOADTYPE Dead TITLE D
MEMBER LOAD
1 UNI GY -20
LOAD 2 LOADTYPE Live TITLE L
1 UNI GY -100
LOAD COMB 3 1.25D+1.5L
1 1.25 2 1.5
LOAD COMB 4 0.85D+1.5L
1 0.85 2 1.5
LOAD COMB 5 1.0L
2 1.0
PERFORM ANALYSIS
DEFINE ENVELOPE
3 4 ENVELOPE 1 TYPE STRENGTH
5 ENVELOPE 2 TYPE SERVICEABILITY
END DEFINE ENVELOPE
PARAMETER 1
CODE AISC UNIFIED 2005
MAIN 1 ALL
DFF 800 ALL
DJ2 2 ALL
DJ1 1 ALL
TRACK 2 ALL
CHECK CODE ALL
SELECT ALL
PARAMETER 2
FINISH
I tried to use AISC 2010 but for some unknown reason I got output in imperial units, which I dont want to use, so I switch to 2005.
If you look the output file - deflection controls but the load case is 3 (Strength) instead 5 (Serviceability).
So how to limit deflection check to Serviceability envelope?
sasa3k,
As I wrote, the method I suggested works only for AISC 360-10
I forgot to mention that you need to add the line
LOAD LIST ENV 1 2
before PARAMETER 1 in order for the serviceability and strength checks to be based solely on the load cases contained in the respective envelopes.
