Is there some online DGN viewer available? It would be useful to view DGN contents for example from mobile devices and would be OS independent.
Found this one - Teigha Online File Viewer but unfortunately it is an alpha release that is available for ODA members only.
There is also CADViewer Enterprise with this online viewer but Java based - http://www.cadviewer.com/cv-pro/CADViewer.html
Wrong there are still no DGN viewers for mobile devices. What we are looking for is a solution which would be simple and universal for new users to view DGN contents without need to install anything and would be OS independent. Bentley View for example is too complicated and at same time too limited for new users, it requires prior Microstation experience to be usable or requires training. "DGN preview handler" has issues and is not configurable. Mobile imodels could be usable on mobile devices but it lacks dgn to imodel on-the-fly conversion so there is no need for prior conversion process.
There is now DWG viewer for Onedrive/Sharepoint - https://windowsreport.com/autocad-onedrive-sharepoint/ based on https://web.autocad.com
Still there is no similar viewer for DGN/imodels.
