Problem with my forum account?
For a while now I have been experiencing problem with my forum account. If I click my user icon in the upper right corner of the forum page and go to my profile page then select Recent Activity I can only see my activity through June of 2015. I've contributed to a number of forum post since that time and would like to be able to see my more recent activity.
The other day I started a new thread to ask a question in the Microstation forum, but the post does not show up in the forum main page. I also did a search for the exact post title and nothing was found. If I go to start a new post and use the exact same title my original post is displayed as suggested/similar topic. I can click on it and it will take me to my post. This is not the first time this has happened.
My newest post is hear:  http://communities.bentley.com/products/microstation/f/273/t/130517.
Can anyone tell me if there is a problem with my account or some setting that I may have enabled/disabled?
  • Hello mwlong,
    I checked your account and did not see any problems that would prevent you from posting on a forum. Based on your description it sounds like your post may have been moderated, possibly due to certain key terms/phrases in the body of the message. You would normally see a message stating that the most needs to be moderated first. It would indeed disappear until a moderator approves it.
    I do see that your profile was set to disable all activity from showing in activity streams, which likely explains why recent activity is not showing in the Activity tab. I have set these options back to being enabled. Future activity should now show up in the activity stream.
    Please let us know if the issues persist.
    Jesse Dringoli
    Bentley Systems, Inc.
  • Thanks for the info. I see the Activity section has been fixed. Not sure why my post would be flagged by a moderator as it is a straight-forward question. I'll wait to see what happens since I did not receive any notifications about a problem with it.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • Can you identify the forum that it was posted to? MicroStation?
    Jesse Dringoli
