Transportation EngineerApply now »Date: Sep 27, 2017
Transportation Engineer-TRCS-USPI01375249
Description
TRANSPORTATION RAIL ENGINEER
REQUISITION NUMBER: TRCS-USPI01375249
Bombardier Transportation is a world-wide leader in rail technology. From mainline to metro, light rail to locomotives, our strategy is one of continuous development that provides the most effective and innovative rail solutions for today and tomorrow!
Rail Control Solutions (RCS) is Bombardier Transportation’s signaling division. RCS is focused on optimizing the flow of trains and delivering innovative signaling systems which enable the safe and efficient operation of rail networks and trains. A career within RCS enables you to work closely with our world-class engineers and learn more about how your field of study and interests can be applied to the transportation industry so you can create better ways to move the world!
Based in Pittsburgh, Pennsylvania, as the Transportation Engineer you will be responsible for civil and wayside track design using Bentley Inrail and Microstation software. You will develop detailed track alignments for rubber tire rail vehicles, steel wheel metros, and monorails, and light rail vehicles.
In your role you will:
- Develop detailed track alignments including horizontal alignments with crossovers, switches, spiral and curved geometry, vertical alignments and graphically graded crossings;- Develop templates and sections for use in clearance envelope design;- Prepare design drawings, specifications, and criteria;- Partner with the Systems Integration and Performance Engineering groups to optimize alignments for system simulations;- Develop interfaces, specifications and project documentation for proposals and turnkey projects;- Contribute to and perform design reviews and document designs;- Execute all tasks as required and assigned.
Qualifications
As our ideal candidate:
- You hold a Bachelor's degree in Civil or Highway Engineering; a Master’s degree will be considered an asset.- You possess at least five (5) years of experience in a similar civil or highway engineering position with alignment design experience;- You must demonstrate hands-on experience using Bentley Rail Track and Microstation software;- Permanent work authorization in the U.S. is required- You demonstrate the ability to operate independently while establishing strong working relationships with co-workers and cross-functional teams;- You possess strong organizational and prioritization skills;- You demonstrate critical attention to detail and deadlines, and are self-motivated;- You possess the ability to adapt well to change in direction and priorities in a project and deadline-oriented environment;- You demonstrate strong written and verbal English communication skills.
Travel advisory: The incumbent in this position must be able to travel domestically and/or internationally as required (less than 20%)
We thank all applicants for their interest; however, only those under consideration will be contacted.
Your ideas move people.
Bombardier is committed to creating a diverse environment and is proud to be an equal opportunity employer. All qualified applicants will receive consideration for employment without regard to race, color, religion, gender, gender identity or expression, sexual orientation, national origin, genetics, age, disability status, veteran status, or any other characteristic protected by Federal, State, or Local Laws.
Job: Civil DesignPrimary Location: US-PA-PittsburghOrganization: TransportationSchedule: Full-timeEmployee Status: Regular
Job Posting: 04.10.2017, 6:41:48 PM
Nearest Major Market: Pittsburgh Job Segment: Transportation, Engineer, Science, Engineering, Rail
Apply online @ jobs.bombardier.com/.../
