MS 08.05.02.35
We have a client .ucf which defines several of the cell configuration variables that would be used for all projects for that client. The following lines appear in that .ucf:
MS_CELL = $(cadd_standards)cells/ MS_CELLOUT = $(cadd_standards)cells/ MS_CELLLIST = $(cadd_standards)cells/*.cel
Then I wanted to prepend those variable definitions at the project level with project specific data. So, I added the following data to a project .pcf:
MS_CELL < $(Project) MS_CELLOUT = $(Project) MS_CELLLIST < $(Project)*.cel
But, microstation is not prepending the variables. When I check them in Microstation, they return the definition from the .ucf only. And, yes the $(Project) variable is defined in the .pcf. I can't figure out why the prepend isn't working, considering that the untitled.pcf delivered with the software includes the same thing.
Any help would be appreciated.
Dave
