Unable to create files using the "Create File" option in the FDOT ribbon bar in SS4
When using the "Create File" option in the FDOT ribbon bar in SS4, I am unable to create the file.  It consistently tells me that the output folder must be a sub-folder to the project folder, which the output folder is. Any ideas?
  • Hello Melody, this question would be better answered in the respective Product Community forum. What Bentley product are you using? MicroStation? OpenRoads Designer?
    Jesse Dringoli
    Bentley Systems, Inc.
