Q: I have local hosting of MS licenses. Select server reports daily client usage only NEXT day.
I don' t know, that today I use more than I can.
How can I reduce number of licenses on my site?
In prewiev versions (8.5) I can read peak usage and I can not start more MS.
best regards
Marek
Phil Chouinard:Usage is summarized after 24 hours and in the current implementation of SELECT Server, there is no *cap* to usage. All this has been brought up, discussed, and explained previously.
After but not now. I tried find previously discussions but no results. Maby links?
Marek,
This was discussed on the Licensing with SELECT Server Community Forum (link)
http://communities.bentley.com/Communities/Other_Communities/Licensing_with_SELECT_Server/f/31752/t/15296.aspx
It's something that we've looked at as we were 'overusing' our licenses but on detailed investigation we were running simultaneously but not if we took the used time over a working day (managing in-house?). The trust licensing won't stop a user having access to the software. I could suggest that your SELECT Server Administrator keep a close eye on the use - we are fortunate enough that all our users are within the same office / department so it's easier for us to keep a lid on 'overuse'
HTH
Ronald Lindsay
