I've created a blog, which may or may not surprise some of you bearing in mind what I said about blogs in general, but there you go. Anyway the reason for the post is that the Blog title is not showing at http://communities.bentley.com/blogs/Bloggers.aspx - see screenshot. Is there a reason for this?
>It's under Peer Blogs...
I know, but that wasn't the problem. The issue seems to be resolved now as the title has appeared. Certainly wasn't there when I did the screenshot.
