Hi there,
most discussion and tips around dual monitor settings for MicroStation here relate to WinXP. For example tips like
1. Use Extended Desktop instead DualView to avoid Performance Penalty on second Monitor and to avoid glitches
2. Use one Application Window to avoid glitches
3. Dont maximize a View to avoid glitches.
(I've seen such a list recently, but cant find it again, so details might be inaccurate)
Now, Win7 ist different, hopefully better. Hint no 1. from the list above doesn't even work anymore, cause Win7 only provides the Dual View strategy. So I wanna ask about Win7 observations and issues with MicroStation, and if there are hints to work around issues:
Whatever came up, please throw into discussion here. THX!
Bigean
We've been running Microstation on Windows 7 with dual-monitor setups for quite a while now, without any problems (contrary to XP, as you also have mentioned).
I run a NVidia dual-dvi head card and have no issues due to two monitors.
--Robert
Thanks both of you for answering.
Seems unbelievable that there are no issues ;) Ok, maybe the reason why it's recently quite regarding that field. Let's see
