Hi
We've been using QuickPipe for several years from SE through V8XM and now that we on a 64 bit workstation in V8i SS2 the vendor is no longer supporting nor upgrading.
We need a replacement Tool. Has anyone used QuickPipe and found an appropriate replacement tool for it? I've found CADcells.com has anyone used their product? Any suggestions gratefully accepted.
Darlene
Unknown said:Now that we on a 64 bit workstation in V8i SS2 the vendor is no longer supporting nor upgrading
Many of us are using MicroStation V8i on a 64-bit workstation with a 64-bt operating system (OS), and many continue to use the same version of MIcroStation on a 32-bit OS. MicroStation remains a 32-bit application. An add-on written for MicroStation doesn't need to know whether the OS is 64-bit or 32-bit. The QuickPipe vendor must have some other agenda.
