Different ratio values for a steel member
Hi everyone,
I get different ratio for steel members in the output file and in the design result in the post processing mode. The pictures I took for member 7 is showing the ratio in the design result is 0.885, but when I go to the output file I see the same member got a ratio of 1.014. which one is the correct value?
