Certification
Can i have a combined certificate for a particular software instead of certificates for every video watched?
  • Hi Prateek,
    Thank you for contacting us!
    As per an automated process in the system, we provide certificates on the basis of the Learning paths which are counted as Learning units. Every Learning path has modules, and for every covered module, a certificate is provided as a transcript in the system.
    Let me know if there is anything else I can help you with. You can write to us at academic@bentley.com.
    Best Regards,
    Shivangi Saurav
