Staad Pro CONNECT Edition Code Error
I have a problem when I try to invoke AISC 360-16 CHECK CODE command the program stop from working and then crash when the analysis is complete and this happen only with AISC 360-16 I tried to use the check code command for AISC 360-10 and the program runs without problem. Any one have an idea what causes STAAD to crash? because I want to use AISC 360-16 for my model.
