Microstation Basics ON-Demand Course - Controlling the Display of Designs Assessment Module - Problem!
I'm experiencing some issues with the Assessment related to the 'Controlling the Display of Designs' module of the ON-Demand Course of Microstation Basics.  I'm having a problem with answer 18 of 20. I cannot seem to find any combination of answers which is accepted as correct. I have attached a screenshot of the two answers that I established to be correct by trying all combination in a Microstation exercise.
Even when I skip question 18 and finish out the course the assessment hangs on the processing results screen and doesn't give me my result of show the assessment as attempted / completed.
Please could you review this assessment module to see if everything is ok with the module?  If I have the wrong answers to Question 18, I'd be grateful if you could let me know.
Many Thanks,
Padraig Daly
Mott MacDonald Ireland
  • Apologies, I have now resolved the issue with Question 18 of 20. The assessment still hangs on the processing results screen though.
  • Padraig Daly,
    I have looked into your issue.  I was not able to recreate the hang-up with the assessment when I chose the answers for this particular question nor at the Result Screen.  There are 3 total correct answers for Question #18.  They are:
    • “Right-click on the level list in the Level Display dialog, in the context menu select Off By Element, and then select one or more elements in the view.”
    • “Select element(s) with the Element Selection tool, right-click on the level list in the Level Display dialog, in the context menu select Off By Element, and accept with a data point.”
    • “Right-press in the view, in the context menu select Level Off, and then select one or more elements in the view.”
    Please let know if you have any further questions or comments.
    Best regards,
    John Melbert
    Bentley Systems, Inc.
    This is a test
