Bentley Learn
Hi, I am very new to Microstation. Been using AutoCAD for years.
I need help with the learning path. I am stuck even before I have started . I cannot get the window below to setup the training course. Where do I go to get this window.
Maybe it because I am using Windows 7 but I need to know how to get the learning path started.
Cant find this window
Rob
  • This is the main File Open dialog after you install MicroStation CONNECT Edition. Have you installed the software? It should the first thing you see when you double click on the icon on your desktop. What are you actually seeing? This window does not setup the training course. Exactly what do you mean?
    Andrew Bell
    Technical Support
    Bentley Systems
