When I place a Spot Elevation, the text that get placed adds additional spaces depending on the accuracy to the end of the text and messes up the alignment of justification.
If you use an accuracy of 0.1234, it works correctly, but anything less appends empty spaces to the end.
Are there any settings that I am missing?
