Hi
I know Steel.ma is very old, but it still works. I was wondering if it is possible to change the MDL coding, so that users can force the colours, weights etc to a cad standards via a dgnlib
At the moment it relies on a save setings, thus, users can override the values.
Ian
Would you want this to be a toggle that just says use the active template or would you want to select a template from the settings?
Rgds,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Hi Mark
Been a long time.
A toggle will be good. But a link to settings will be great, thus users can then have total control.
Ian Lapper [ex bentley]
Hi Arjan
Here you go.... (I think its attached)
steel.zip
