Does anybody have a working Atool for V8i or another good solution?
t.
? Working ATool.
The ATools v08.09.02.01 seems to work in Ss2 & Ss3 for a Basic Area Text tool.
communities.bentley.com/.../default.aspx
Text "Fields" would be a better choice depending on what you want.
There are other tools available outside basic MicroStation thru VBA, MDL or add-on packages (i.e. AECOSIM, etc.)
What is it doing/not doing or what do you want that it doesn't do?
I Hope this Helps!
Unknown said:Does anybody have a working Atool for V8i or another solution?
AreaAnnotator is a freeware tool for MicroStation. It augments MicroStation tags to measure area objects automatically. It updates a measurement when you modify an area object.
Area measurements are displayed using MicroStation tags. A benefit of tags over text fields is that it's easy to export DGN model area measurements using MicroStation's built-in tag reporting tools. AreaAnnotator is freeware.
ShapeTagger is a tool to tag multiple shape elements with area information. It calls on AreaAnnotator to perform measurements on each shape element it finds on a specified level.
ShapeTagger is freeware. It is a MicroStation VBA macro complete with source code, so you can adapt it to your needs. ShapeTagger is included in the AreaAnnotator download.
Thanks Guys, I found a working copy.
Thomas Gnauck can you tell me where did you find a working copy...?
or please tell me step by step how to install atool.ma properly.
Thanks.
MS
