I customized the MS material rendering template using photographs, which photographs I downloaded from the Internet. After I customized it, I exported it to the .mat template, but after I imported it on other computers, the material of my customized template is displayed as missing material, so I can't use the customized template. I wonder if I downloaded the image and didn't have it in the new computer. I imported the material file of the entire template into the It is copied and replaced, but the result is still the same. What's the problem? What's the normal way?Which teacher can help me out?
thanks very much!
Am I rendering material photos in the wrong place? The path of my photos is (OBD U6) C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\worksets\BuildingTemplate_CN\Standards\Materials
是你拷贝的路径不对吧 再个我们支持是中国人 你不用用英文
Answer Verified By: Ruan Jian 阮健
你好 这个路径好像不对 请参看如下链接:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/43193/page
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/43194/page
(如果您对我的回答满意,望您帮我在more选项下“Verify Answer”,如没有欢迎您继续跟帖,我将为您进一步解答)
是这样的,因为在OBD ce版本中有如下三种材质路径分别是:1、C:\ProgramData\Bentley\connectsharedcontent 导出外部(.mat)表默认位置;2、
C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_CN\Materials导入外部(.mat)表默认位置;3. C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\worksets\BuildingTemplate_CN\Standards\Materials 图像贴图默认位置,因此,我将我网上下载的照片,放在以上三个路径中的那个路径的文件夹内,再进行自定义设置材质,导出.mat文件以后,在其他电脑上在导入,我自定义的材质还能继续存在并能继续使用?您发给我的链接我也看了,里面的内容讲的不是很清楚,我也不是很明白,希望老师您能给我答疑一下,万分感谢!
您好,我已经在中国优先上找到了相关的文件,谢谢您
