[3520:350C][2019-12-07T17:17:35]i001: Burn v3.11.1.2318, Windows v10.0 (Build 17763: Service Pack 0), path: C:\Users\tang\AppData\Local\Temp\{43C5AAEB-0245-4B3A-BAAC-0BBAD89FC604}\.cr\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeExeName' to value 'CNCCBIMOpenRoads'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'CHS'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]CNCCBIMOpenRoads\ActivationWizard.exe'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeIF_PromptCloseApplication' to value 'cnccbimopenroads'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\CNCCBIMOpenRoads\'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CNCCBIMOpenRoads\'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\CNCCBIMOpenRoads\Configuration'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeKBBuddiName' to value 'MicroStation_KB_Requirements'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'PackageCacheHtmlHelpPageGuid' to value 'GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{27423539-8B45-4096-9817-827BDEB6B319}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBuildType' to value 'Release'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBundleShortName' to value 'CNCCBIMOpenRoads'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_CNCCBIMOpenRoads_zh-CN.zip'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '65134'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_KB2803801_LANGUAGE_PRGID' to value '67813'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTInstallDirectory' to value '[ProgramFiles64Folder]Bentley\Bentley LumenRT CONNECT Edition - Update 12'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTDocumentDirectory' to value '[CommonAppDataFolder]Bentley\Bentley LumenRT CONNECT Edition - Update 12'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTUserDocumentDirectory' to value '[PersonalFolder]Bentley\Bentley LumenRT CONNECT Edition'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{D7315727-407E-310A-A598-3517F0DA8659}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{D7315727-407E-310A-A598-3517F0DA8659}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{C3B6626D-1661-3522-AEBA-C94863527F83}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{C3B6626D-1661-3522-AEBA-C94863527F83}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMCCKBundleModule' to value '{61AF933E-BD4E-316C-9F3A-30CC3605EAFD}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMCCKBundleModule' to value '{61AF933E-BD4E-316C-9F3A-30CC3605EAFD}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMWorkSpacesBundleModule' to value '{C0FC36FA-2637-3DB5-80F7-390F839C12DB}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMWorkSpacesBundleModule' to value '{C0FC36FA-2637-3DB5-80F7-390F839C12DB}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{11A561B0-FC3A-4237-B5E1-D37C3E89641B}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{11A561B0-FC3A-4237-B5E1-D37C3E89641B}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{0378B8FA-79D8-3736-8168-50A65B8EB857}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{0378B8FA-79D8-3736-8168-50A65B8EB857}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}'[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}'[3520:350C][2019-12-07T17:17:35]i009: Command Line: '"-burn.clean.room=G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe" -burn.filehandle.attached=728 -burn.filehandle.self=180'[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleOriginalSource' to value 'G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe'[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735.log'[3520:350C][2019-12-07T17:17:35]i052: Condition 'VersionNT64 > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.[3520:350C][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleName' to value 'CNCCBIM OpenRoads'[3520:350C][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'[3520:350C][2019-12-07T17:17:36]i000: Loading managed bootstrapper application.[3520:350C][2019-12-07T17:17:36]i000: Creating BA thread to run asynchronously.[3520:2988][2019-12-07T17:17:36]i000: Setting Culture Info to zh-CN[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BeSelectedLanguage' to value 'zh-CN'[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''[3520:2988][2019-12-07T17:17:36]i000: BentleyBundle Version 12.00.00.11[3520:2988][2019-12-07T17:17:36]i000: TRY Set TLS 1.2[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.ba'[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\tang\AppData\Local\Temp\{43C5AAEB-0245-4B3A-BAAC-0BBAD89FC604}\.cr'[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'[3520:2988][2019-12-07T17:17:36]e000: Using Layout File : C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.ba\Setup.lyt[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCore InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCoreKB2803801 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCoreKB3061498 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCorepatch InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLang InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLangPackKB2803801 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLang2 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLangPackKB2803801_2 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting DotNet452Full InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting VCRedistx64 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting BentleyConnectClient InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting BentleyAdvisor InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting ItgDgnDbImporter InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting PowerProductPackage InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,OptionalFeature,TechPreview,assetmanagertoken,Configuration,FileAssociationFeature'[3520:2988][2019-12-07T17:17:37]i000: Setting CivilDesignWorkSpaceBundleModule InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting CNCCBIMCCKBundleModule InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting CNCCBIMWorkSpacesBundleModule InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting PointTools32Extx86 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting DgnIndexer InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting DgnThumbnailProvier InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting ItgDgnDbImporter_v2 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting DPH InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting LumenRT2017 InstallLevel to 1[3520:2988][2019-12-07T17:17:37]i000: Setting PowerProductLanguagePack InstallLevel to 1[3520:2988][2019-12-07T17:17:37]e000: LoadTestAutomationApp(): Failed to load test dll with error 未将对象引用设置到对象的实例。[3520:2988][2019-12-07T17:17:37]e000: Failed for Package Id: PowerProductPackage_WinTabFeature Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature[3520:2988][2019-12-07T17:17:37]i000: Setting string variable 'BePrimaryProductName' to value 'CNCCBIM OpenRoads'[3520:2988][2019-12-07T17:17:41]i000: Display is set to Full[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml[3520:2988][2019-12-07T17:17:41]i000: Register callbak=ProxySettingsPage[3520:2988][2019-12-07T17:17:41]i000: Display Page=ProxySettingsPage[3520:2988][2019-12-07T17:17:41]i000: Cannot Display Page=ProxySettingsPage[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductInstallDirSelectionUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductConfigurationSettingsUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductSelectionUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductFeatureSelectionUserControl.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /LumenRTExtension;v1.0.0.0;component/InstallDirSelection.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /LumenRTExtension;v1.0.0.0;component/LumenRTUserInformation.xaml[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RedefineWixPackageCacheUserControl.xaml[3520:350C][2019-12-07T17:17:42]i100: Detect begin, 26 packages[3520:350C][2019-12-07T17:17:42]i000: PCRA: Checking running instances.[3520:350C][2019-12-07T17:17:42]i000: PCRA: Command Action - Install[3520:350C][2019-12-07T17:17:42]i000: PCRA: Command Display - Full[3520:350C][2019-12-07T17:17:42]i000: PCRA: No running instances.[3520:350C][2019-12-07T17:17:42]i000: PCRA: Exiting from prompt.[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Current Image is not running from a Deployment Image.[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check.[3520:350C][2019-12-07T17:17:42]i000: Trying to connect to BUDDI, Retry Count = 1. Local Retry Count = 1[3520:350C][2019-12-07T17:17:48]i000: BeSkipKBCheck : [3520:350C][2019-12-07T17:17:48]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[3520:350C][2019-12-07T17:17:48]i000: DetectBegin: Installed State of Package DetectedAbsent[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BentleyAdvisorItInstalledVersion' to value '10.01.00.135'[3520:2988][2019-12-07T17:17:48]i000: ErrorPage Code: 0[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.17.010'[3520:350C][2019-12-07T17:17:48]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{12E5758F-720C-3119-8E7C-6FF83F77BDEC}'[3520:350C][2019-12-07T17:17:48]i000: Setting numeric variable 'LanguagePackRegistry' to value 0[3520:350C][2019-12-07T17:17:48]i000: Registry key not found. Key = 'SOFTWARE\Bentley\LumenRT\Bentley LumenRT CONNECT Edition'[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'NetFramework45Version' to value '461814'[3520:350C][2019-12-07T17:17:48]i000: Product or related product not found: {1CC0EABA-3397-4893-833E-56BE22820105}[3520:350C][2019-12-07T17:17:48]i000: Setting numeric variable 'PRODSEARCHITG15INSTALLED' to value 2[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90120064-0070-0000-0000-4000000FF1CE}, context: Machine[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90F60409-7000-11D3-8CFE-0150048383C9}, context: Machine[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90F60804-7000-11D3-8CFE-0150048383C9}, context: Machine[3520:350C][2019-12-07T17:17:48]i052: Condition '(NetFramework45Version >= 394802)' evaluates to true.[3520:350C][2019-12-07T17:17:48]i052: Condition 'VC14_vcredist_x64_Installed' evaluates to true.[3520:350C][2019-12-07T17:17:48]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.13.17' evaluates to true.[3520:350C][2019-12-07T17:17:48]i052: Condition 'BentleyAdvisorItInstalledVersion >= v10.1.0.135' evaluates to true.[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[3520:350C][2019-12-07T17:17:48]w120: Detected partially cached package: DPH, invalid payload: DPH, reason: 0x80070002[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {0378B8FA-79D8-3736-8168-50A65B8EB857}, scope: PerMachine, version: 10.11.0.4, language: 1033 operation: MinorUpdate[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MinorUpdate[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {A73C1780-0589-48DA-956A-20A1FB7C1443}, scope: PerMachine, version: 8.11.8008.0, language: 0 operation: MajorUpgrade[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {264B522D-1B7F-4AAF-A32B-55A6BF5679F2}, scope: PerMachine, version: 8.11.8004.0, language: 0 operation: MajorUpgrade[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[3520:350C][2019-12-07T17:17:48]i052: Condition 'LumenRTInstalledVersion >= v16.12.22.66' evaluates to false.[3520:350C][2019-12-07T17:17:48]w120: Detected partially cached package: PowerProductLanguagePack, invalid payload: PowerProductLanguagePack, reason: 0x80070570[3520:350C][2019-12-07T17:17:48]i052: Condition 'LanguagePackRegistry = v10.07.01.011' evaluates to false.[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCore, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCoreKB2803801, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCoreKB2803801 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCoreKB3061498, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCoreKB3061498 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCorepatch, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCorepatch target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLang, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLangPackKB2803801, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicLangPackKB2803801 target: {90F60409-7000-11D3-8CFE-0150048383C9}, state: Present[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLang2, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLangPackKB2803801_2, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicLangPackKB2803801_2 target: {90F60804-7000-11D3-8CFE-0150048383C9}, state: Present[3520:350C][2019-12-07T17:17:48]i101: Detected package: DotNet452Full, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: VCRedistx64, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: BentleyConnectClient, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: BentleyAdvisor, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: PowerProductPackage, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: OptionalFeature, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: TechPreview, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: assetmanagertoken, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: PPDesktopShortcut, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent[3520:350C][2019-12-07T17:17:48]i101: Detected package: CivilDesignWorkSpaceBundleModule, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: CNCCBIMCCKBundleModule, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: CNCCBIMWorkSpacesBundleModule, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: PointTools32Extx86, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnIndexer, state: Present, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: ItgDgnDbImporter_v2, state: Absent, cached: Complete[3520:350C][2019-12-07T17:17:48]i101: Detected package: DPH, state: Present, cached: Partial[3520:350C][2019-12-07T17:17:48]i101: Detected package: LumenRT2017, state: Absent, cached: None[3520:350C][2019-12-07T17:17:48]i101: Detected package: PowerProductLanguagePack, state: Absent, cached: Partial[3520:350C][2019-12-07T17:17:48]i000: Detect complete Start[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BePlannedAction' to value 'Install'[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Install[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[3520:350C][2019-12-07T17:17:49]i000: Detection complete planned action: Install[3520:350C][2019-12-07T17:17:49]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle[3520:350C][2019-12-07T17:17:49]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0[3520:350C][2019-12-07T17:17:49]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Creating new SessionMutex[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Creating Mutex with Name={ac65c314-2ade-4fb2-9452-9e2c0d5265af}-InstallMutex[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True[3520:350C][2019-12-07T17:17:49]i000: WixInstallBA::SilentPlan[3520:350C][2019-12-07T17:17:49]i000: [3520:350C][2019-12-07T17:17:49]i000: Checking ADDLOCAL and REMOVE...[3520:350C][2019-12-07T17:17:49]e000: baApplication_DetectWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg[3520:350C][2019-12-07T17:17:49]i000: AutoCad Civil 3D ObjectEnabler:Searching[3520:350C][2019-12-07T17:17:49]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler[3520:350C][2019-12-07T17:17:49]e000: baCustomConfigurationPath:Start[3520:350C][2019-12-07T17:17:49]i199: Detect complete, result: 0x0[3520:2988][2019-12-07T17:17:51]e000: In Sequence current and the next UI are same, please change the sequence and try again[3520:2988][2019-12-07T17:17:51]i052: Condition 'NOT BeUpgradingProductCodes' evaluates to true.[3520:2988][2019-12-07T17:17:55]i000: Setting string variable 'InstallDirectory' to value 'F:\Program Files\Bentley\CNCCBIMOpenRoads\'[3520:2988][2019-12-07T17:18:01]i000: Setting string variable 'ConfigurationDirectory' to value 'F:\ProgramData\Bentley\CNCCBIMOpenRoads\'[3520:2988][2019-12-07T17:18:09]i000: WixInstallBA::Plan[3520:2988][2019-12-07T17:18:09]i000: WixInstallBA::SetupModel Plan[3520:2988][2019-12-07T17:18:09]i000: SetupModel::Before Plan[3520:3B90][2019-12-07T17:18:09]i000: Before Plan Async[3520:3B90][2019-12-07T17:18:09]i000: SetupViewModel::Before Plan[3520:3B90][2019-12-07T17:18:09]i000: IsAnythingToDownload: Demanded by ItgDgnDbImporter[3520:3B90][2019-12-07T17:18:09]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1[3520:3B90][2019-12-07T17:18:09]i000: WixInstallBA::Before Plan Complete[3520:3B90][2019-12-07T17:18:09]i000: WixInstallBA::Engine Plan[3520:350C][2019-12-07T17:18:09]i200: Plan begin, 26 packages, action: Install[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'LumenRTInstallDirectory' to value 'C:\Program Files\Bentley\Bentley LumenRT CONNECT Edition - Update 12\'[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: DotNet452Full[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: VCRedistx64[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: BentleyAdvisor[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_ItgDgnDbImporter' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_000_ItgDgnDbImporter.log'[3520:350C][2019-12-07T17:18:09]i204: Plan 7 msi features for package: PowerProductPackage[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_DefaultFeature_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_OptionalFeature_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: OptionalFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_TechPreview_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: TechPreview, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: assetmanagertoken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_PPDesktopShortcut_IsNotInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: PPDesktopShortcut, state: Absent, default requested: Unknown, ba requested: Absent, execute action: None, rollback action: None[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_Configuration_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: Configuration, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_IsInstalling' to value '1'[3520:350C][2019-12-07T17:18:09]i203: Planned feature: FileAssociationFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_PowerProductPackage' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_001_PowerProductPackage_rollback.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_PowerProductPackage' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_001_PowerProductPackage.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_002_CivilDesignWorkSpaceBundleModule_rollback.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_002_CivilDesignWorkSpaceBundleModule.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CNCCBIMCCKBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_003_CNCCBIMCCKBundleModule_rollback.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CNCCBIMCCKBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_003_CNCCBIMCCKBundleModule.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CNCCBIMWorkSpacesBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_004_CNCCBIMWorkSpacesBundleModule_rollback.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CNCCBIMWorkSpacesBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_004_CNCCBIMWorkSpacesBundleModule.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_ItgDgnDbImporter_v2' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_005_ItgDgnDbImporter_v2.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_DPH' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_006_DPH.log'[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: LumenRT2017[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: PowerProductLanguagePack[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_PowerProductLanguagePack' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_007_PowerProductLanguagePack.log'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_PowerProductLanguagePack' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_007_PowerProductLanguagePack_rollback.log'[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCore, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCoreKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCoreKB3061498, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCorepatch, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLang, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLangPackKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLang2, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLangPackKB2803801_2, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: DotNet452Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i201: Planned package: VCRedistx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i201: Planned package: BentleyConnectClient, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i201: Planned package: BentleyAdvisor, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i201: Planned package: ItgDgnDbImporter, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: PowerProductPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: CivilDesignWorkSpaceBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: CNCCBIMCCKBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: CNCCBIMWorkSpacesBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: PointTools32Extx86, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnIFilterSetUpx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnIndexer, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnThumbnailProvier, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: HDRPreviewExtension_x64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: ItgDgnDbImporter_v2, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: DPH, state: Present, default requested: Present, ba requested: Present, execute: MinorUpgrade, rollback: None, cache: Yes, uncache: No, dependency: Register[3520:350C][2019-12-07T17:18:09]i201: Planned package: LumenRT2017, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i201: Planned package: PowerProductLanguagePack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None[3520:350C][2019-12-07T17:18:09]i000: GetWindowsRootDriveName (): winRoot=C:\[3520:350C][2019-12-07T17:18:09]i000: IsPathRooted (C:\): true[3520:350C][2019-12-07T17:18:09]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=416993192, FileName=G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=416993192[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=859677478, NewSize=1276670670[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1276670670[3520:350C][2019-12-07T17:18:09]i000: IsPathRooted (F:\): true[3520:350C][2019-12-07T17:18:09]i000: GetDriveName (F:\): DriveInfo.Name=F:\[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): DriveName=F:\, Path=F:\Program Files\Bentley\CNCCBIMOpenRoads\[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Adding DriveName=F:\, Size=4373790661, NewSize=4373790661[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Configurations. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Application Options. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = File association. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Desktop Shortcut. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Technology Preview Features. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Asset Manager. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1276670670[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=394494298, NewSize=1671164968[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1671164968[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=12966717, NewSize=1684131685[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1684131685[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=6363952, NewSize=1690495637[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Pointools32Ext. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN IFilter. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley Dgn Index Service. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Thumbnail Provider. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = HDR Preview. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1690495637[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1688304823, NewSize=3378800460[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Preview Handler. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3378800460[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=0, NewSize=3378800460[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB2803801). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB3061498). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = VBA Patch. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) English. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB2803801). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) Chinese (Simplified). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB2803801). Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.2. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23026. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECTION Client. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECT Advisor. Next[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3378800460[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2005889248, NewSize=5384689708[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive C:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Requested Drive-List contains drive C:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive D:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive E:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive F:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Requested Drive-List contains drive F:\[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive G:\[3520:350C][2019-12-07T17:18:09]i000: validateInstallSize (): Result=True[3520:350C][2019-12-07T17:18:09]i000: PlanComplete: Called[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'ItgDgnDbImporter_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_Configuration_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_OptionalFeature_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_TechPreview_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CivilDesignWorkSpaceBundleModule_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CNCCBIMCCKBundleModule_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CNCCBIMWorkSpacesBundleModule_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PointTools32Extx86_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnIFilterSetUpx64_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnIndexer_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnThumbnailProvier_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'HDRPreviewExtension_x64_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'ItgDgnDbImporter_v2_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DPH_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductLanguagePack_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCore_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCoreKB2803801_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCoreKB3061498_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCorepatch_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLang_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLangPackKB2803801_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLang2_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLangPackKB2803801_2_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DotNet452Full_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VCRedistx64_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'BentleyAdvisor_RequestedState' to value '1'[3520:350C][2019-12-07T17:18:09]i000: WixInstallBA::Apply[3520:350C][2019-12-07T17:18:09]i000: WixInstallBA::Engine Apply[3520:350C][2019-12-07T17:18:09]i299: Plan complete, result: 0x0[3520:350C][2019-12-07T17:18:09]i300: Apply begin[3520:2988][2019-12-07T17:18:09]i000: ErrorPage Code: 0[3520:350C][2019-12-07T17:18:09]i010: Launching elevated engine process.[3520:350C][2019-12-07T17:18:10]i011: Launched elevated engine process.[3520:350C][2019-12-07T17:18:11]i012: Connected to elevated engine.[2718:218C][2019-12-07T17:18:11]i358: Pausing automatic updates.[2718:218C][2019-12-07T17:18:11]i359: Paused automatic updates.[2718:218C][2019-12-07T17:18:11]i360: Creating a system restore point.[2718:218C][2019-12-07T17:18:11]w363: Could not create system restore point, error: 0x80070422. Continuing...[2718:218C][2019-12-07T17:18:11]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, options: 0x7, disable resume: No[2718:218C][2019-12-07T17:18:11]i000: Caching bundle from: 'C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.be\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe' to: 'C:\ProgramData\Package Cache\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe'[2718:218C][2019-12-07T17:18:11]i320: Registering bundle dependency provider: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}, version: 10.7.1.11[2718:218C][2019-12-07T17:18:11]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: Active, restart initiated: No, disable resume: No[3520:350C][2019-12-07T17:18:11]i000: Installation chain initiated package from [2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, version: 7.1.00.00, package: VisualBasicCore[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, version: (null), package: VisualBasicCoreKB2803801[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, version: (null), package: VisualBasicCoreKB3061498[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, version: (null), package: VisualBasicCorepatch[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, version: (null), package: VisualBasicLangPackKB2803801[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang2[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, version: (null), package: VisualBasicLangPackKB2803801_2[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package: VisualBasicLangPackKB2803801_2[2718:4434][2019-12-07T17:18:13]i304: Verified existing payload: ItgDgnDbImporter at path: C:\ProgramData\Package Cache\{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}v1.6.7.5\ItgDgnDbImporter_1.6_x64.msi.[2718:218C][2019-12-07T17:18:13]i323: Registering package dependency provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, version: 1.6.7.5, package: ItgDgnDbImporter[3520:350C][2019-12-07T17:18:13]i000: Installing ItgDgnDbImporter[3520:350C][2019-12-07T17:18:13]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;itgdgndbimporter'[2718:218C][2019-12-07T17:18:13]i301: Applying execute package: ItgDgnDbImporter, action: Install, path: C:\ProgramData\Package Cache\{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}v1.6.7.5\ItgDgnDbImporter_1.6_x64.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7" PRODITG15INSTALLED="5"'[2718:4434][2019-12-07T17:18:21]i304: Verified existing payload: PowerProductPackage at path: C:\ProgramData\Package Cache\{D7315727-407E-310A-A598-3517F0DA8659}v10.07.01.011\CNCCBIMOpenRoadsx64.msi.[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CivilDesignWorkSpaceBundleModule at path: C:\ProgramData\Package Cache\{C3B6626D-1661-3522-AEBA-C94863527F83}v10.07.01.011\CivilDesignWorkSpacex64.msi.[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CNCCBIMCCKBundleModule at path: C:\ProgramData\Package Cache\{61AF933E-BD4E-316C-9F3A-30CC3605EAFD}v10.07.01.011\CNCCBIMCCKx64.msi.[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CNCCBIMWorkSpacesBundleModule at path: C:\ProgramData\Package Cache\{C0FC36FA-2637-3DB5-80F7-390F839C12DB}v10.07.01.011\CNCCBIMWorkSpacesx64.msi.[2718:4434][2019-12-07T17:18:25]i304: Verified existing payload: ItgDgnDbImporter_v2 at path: C:\ProgramData\Package Cache\{11A561B0-FC3A-4237-B5E1-D37C3E89641B}v2.0.2.76\ItgDgnDbImporter_2.0_x64.msi.[3520:0850][2019-12-07T17:18:25]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi[3520:0850][2019-12-07T17:18:26]i000: Setting string variable 'WixBundleLastUsedSource' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Failed to verify hash of payload: DPH[2718:4434][2019-12-07T17:18:27]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Failed to cache payload: DPH[3520:0850][2019-12-07T17:18:27]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 0[3520:0850][2019-12-07T17:18:27]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.[3520:0850][2019-12-07T17:18:27]e349: Application requested retry of payload: DPH, encountered error: 0x80091007. Retrying...[3520:0850][2019-12-07T17:18:27]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Failed to verify hash of payload: DPH[2718:4434][2019-12-07T17:18:29]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Failed to cache payload: DPH[3520:0850][2019-12-07T17:18:29]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 1[3520:0850][2019-12-07T17:18:29]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.[3520:0850][2019-12-07T17:18:29]e349: Application requested retry of payload: DPH, encountered error: 0x80091007. Retrying...[3520:0850][2019-12-07T17:18:29]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Failed to verify hash of payload: DPH[2718:4434][2019-12-07T17:18:33]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Failed to cache payload: DPH[3520:0850][2019-12-07T17:18:33]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 2[3520:0850][2019-12-07T17:18:33]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.[3520:0850][2019-12-07T17:18:33]e000: Caching failed for DPH[3520:0850][2019-12-07T17:18:33]w350: Applied non-vital package: DPH, encountered error: 0x80091007. Continuing...[2718:4434][2019-12-07T17:18:35]i304: Verified existing payload: PowerProductLanguagePack at path: C:\ProgramData\Package Cache\B60D36643F452F7A04087854E0CA3C08259E15B9\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_LangPack.exe.[3520:350C][2019-12-07T17:18:37]i000: Installed package ItgDgnDbImporter[3520:350C][2019-12-07T17:18:37]i319: Applied execute package: ItgDgnDbImporter, result: 0x0, restart: None[2718:218C][2019-12-07T17:18:37]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package: ItgDgnDbImporter[2718:218C][2019-12-07T17:18:37]i323: Registering package dependency provider: {D7315727-407E-310A-A598-3517F0DA8659}, version: 10.07.01.011, package: PowerProductPackage[3520:350C][2019-12-07T17:18:37]i000: Installing PowerProductPackage[3520:350C][2019-12-07T17:18:37]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;itgdgndbimporter;powerproductpackage'[2718:218C][2019-12-07T17:18:37]i301: Applying execute package: PowerProductPackage, action: Install, path: C:\ProgramData\Package Cache\{D7315727-407E-310A-A598-3517F0DA8659}v10.07.01.011\CNCCBIMOpenRoadsx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLDIR="F:\Program Files\Bentley\CNCCBIMOpenRoads\" PACKAGE_HOMEROOT="F:\ProgramData\Bentley\CNCCBIMOpenRoads\" FROMLAUNCHSETUP="1" WIXUI_SHORTCUTSDIALOGDESKTOPCHECKBOX="" BUNDLEPROVIDERKEY="{ac65c314-2ade-4fb2-9452-9e2c0d5265af}" BE_BUNDLE_NAME="CNCCBIM OpenRoads" BE_BUNDLE_VERSION="10.7.1.11" BE_BUNDLE_BUILDTYPE="Release" BE_BUNDLE_DEPLOYMENTIMAGE_GUID="" USER_CONFIGURATION_LOCATION="" ADDLOCAL="DefaultFeature,OptionalFeature,TechPreview,assetmanagertoken,Configuration,FileAssociationFeature"'[2718:218C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to install MSI package.[2718:218C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to execute MSI package.[3520:350C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to configure per-machine MSI package.[3520:350C][2019-12-07T17:20:12]i000: Installed package PowerProductPackage[3520:350C][2019-12-07T17:20:12]i319: Applied execute package: PowerProductPackage, result: 0x80070643, restart: None[3520:350C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to execute MSI package.[3520:350C][2019-12-07T17:20:12]i000: Installing PowerProductPackage[2718:218C][2019-12-07T17:20:12]i318: Skipped rollback of package: PowerProductPackage, action: Uninstall, already: Absent[3520:350C][2019-12-07T17:20:12]i000: Installed package PowerProductPackage[3520:350C][2019-12-07T17:20:12]i319: Applied rollback package: PowerProductPackage, result: 0x0, restart: None[3520:2988][2019-12-07T17:20:12]i000: ErrorPage Code: -2147023293[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {D7315727-407E-310A-A598-3517F0DA8659}, package: PowerProductPackage[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package ItgDgnDbImporter[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package: ItgDgnDbImporter[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package VisualBasicLangPackKB2803801_2[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package: VisualBasicLangPackKB2803801_2[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang2[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package VisualBasicLangPackKB2803801[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package VisualBasicCorepatch[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package VisualBasicCoreKB3061498[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package VisualBasicCoreKB2803801[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package VisualBasicCore[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore[3520:350C][2019-12-07T17:20:12]i000: Installation chain finished package from [2718:218C][2019-12-07T17:20:12]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: None, restart: None, disable resume: No[2718:218C][2019-12-07T17:20:12]i330: Removed bundle dependency provider: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}[2718:218C][2019-12-07T17:20:12]i352: Removing cached bundle: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}, from path: C:\ProgramData\Package Cache\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}\[2718:218C][2019-12-07T17:20:12]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: None, restart initiated: No, disable resume: No[3520:350C][2019-12-07T17:20:12]i000: F:\Program Files\Bentley\CNCCBIMOpenRoads\CNCCBIMOpenRoads\ActivationWizard.exe application is set for launch after installation[3520:350C][2019-12-07T17:20:12]i000: application not found to launch after installation[3520:350C][2019-12-07T17:20:12]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735.zip'[3520:350C][2019-12-07T17:20:12]e000: baApplication_ApplyCompleteWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg[3520:350C][2019-12-07T17:20:12]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
请问您安装的时候是联网的吗?
您可以参考下面的帖子处理下:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/41717/microstation-ce-0x80070643
如果解决了您的问题,请确认答案,方便其他用户参考,同时也感谢您对我们工作的肯定。
请问您的问题解决了吗?注意安装.Net Framework时,中、英文版本的都要安装,在下载的时候会提示选择语言的。
您也看下这个帖子:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/40978/1-abd-ce
