安装错误,按照以前的回答都试过了还是不行
[3520:350C][2019-12-07T17:17:35]i001: Burn v3.11.1.2318, Windows v10.0 (Build 17763: Service Pack 0), path: C:\Users\tang\AppData\Local\Temp\{43C5AAEB-0245-4B3A-BAAC-0BBAD89FC604}\.cr\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeExeName' to value 'CNCCBIMOpenRoads'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'CHS'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]CNCCBIMOpenRoads\ActivationWizard.exe'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeIF_PromptCloseApplication' to value 'cnccbimopenroads'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\CNCCBIMOpenRoads\'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CNCCBIMOpenRoads\'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\CNCCBIMOpenRoads\Configuration'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeKBBuddiName' to value 'MicroStation_KB_Requirements'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'PackageCacheHtmlHelpPageGuid' to value 'GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{27423539-8B45-4096-9817-827BDEB6B319}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBuildType' to value 'Release'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeBundleShortName' to value 'CNCCBIMOpenRoads'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_CNCCBIMOpenRoads_zh-CN.zip'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '65134'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'VBA_KB2803801_LANGUAGE_PRGID' to value '67813'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTInstallDirectory' to value '[ProgramFiles64Folder]Bentley\Bentley LumenRT CONNECT Edition - Update 12'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTDocumentDirectory' to value '[CommonAppDataFolder]Bentley\Bentley LumenRT CONNECT Edition - Update 12'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'LumenRTUserDocumentDirectory' to value '[PersonalFolder]Bentley\Bentley LumenRT CONNECT Edition'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{D7315727-407E-310A-A598-3517F0DA8659}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{C3B6626D-1661-3522-AEBA-C94863527F83}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMCCKBundleModule' to value '{61AF933E-BD4E-316C-9F3A-30CC3605EAFD}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_CNCCBIMWorkSpacesBundleModule' to value '{C0FC36FA-2637-3DB5-80F7-390F839C12DB}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{11A561B0-FC3A-4237-B5E1-D37C3E89641B}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{0378B8FA-79D8-3736-8168-50A65B8EB857}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[3520:350C][2019-12-07T17:17:35]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}'
[3520:350C][2019-12-07T17:17:35]i009: Command Line: '"-burn.clean.room=G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe" -burn.filehandle.attached=728 -burn.filehandle.self=180'
[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleOriginalSource' to value 'G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe'
[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'
[3520:350C][2019-12-07T17:17:35]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735.log'
[3520:350C][2019-12-07T17:17:35]i052: Condition 'VersionNT64 > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[3520:350C][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleName' to value 'CNCCBIM OpenRoads'
[3520:350C][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[3520:350C][2019-12-07T17:17:36]i000: Loading managed bootstrapper application.
[3520:350C][2019-12-07T17:17:36]i000: Creating BA thread to run asynchronously.
[3520:2988][2019-12-07T17:17:36]i000: Setting Culture Info to zh-CN
[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BeSelectedLanguage' to value 'zh-CN'
[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''
[3520:2988][2019-12-07T17:17:36]i000: BentleyBundle Version 12.00.00.11
[3520:2988][2019-12-07T17:17:36]i000: TRY Set TLS 1.2
[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.ba'
[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\tang\AppData\Local\Temp\{43C5AAEB-0245-4B3A-BAAC-0BBAD89FC604}\.cr'
[3520:2988][2019-12-07T17:17:36]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'
[3520:2988][2019-12-07T17:17:36]e000: Using Layout File : C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.ba\Setup.lyt
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCore InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCoreKB2803801 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCoreKB3061498 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicCorepatch InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLang InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLangPackKB2803801 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLang2 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VisualBasicLangPackKB2803801_2 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting DotNet452Full InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting VCRedistx64 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting BentleyConnectClient InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting BentleyAdvisor InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting ItgDgnDbImporter InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting PowerProductPackage InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,OptionalFeature,TechPreview,assetmanagertoken,Configuration,FileAssociationFeature'
[3520:2988][2019-12-07T17:17:37]i000: Setting CivilDesignWorkSpaceBundleModule InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting CNCCBIMCCKBundleModule InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting CNCCBIMWorkSpacesBundleModule InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting PointTools32Extx86 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting DgnIndexer InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting DgnThumbnailProvier InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting ItgDgnDbImporter_v2 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting DPH InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting LumenRT2017 InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]i000: Setting PowerProductLanguagePack InstallLevel to 1
[3520:2988][2019-12-07T17:17:37]e000: LoadTestAutomationApp(): Failed to load test dll with error 未将对象引用设置到对象的实例。
[3520:2988][2019-12-07T17:17:37]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[3520:2988][2019-12-07T17:17:37]i000: Setting string variable 'BePrimaryProductName' to value 'CNCCBIM OpenRoads'
[3520:2988][2019-12-07T17:17:41]i000: Display is set to Full
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[3520:2988][2019-12-07T17:17:41]i000: Register callbak=ProxySettingsPage
[3520:2988][2019-12-07T17:17:41]i000: Display Page=ProxySettingsPage
[3520:2988][2019-12-07T17:17:41]i000: Cannot Display Page=ProxySettingsPage
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductInstallDirSelectionUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductConfigurationSettingsUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductSelectionUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductFeatureSelectionUserControl.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /LumenRTExtension;v1.0.0.0;component/InstallDirSelection.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /LumenRTExtension;v1.0.0.0;component/LumenRTUserInformation.xaml
[3520:2988][2019-12-07T17:17:41]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RedefineWixPackageCacheUserControl.xaml
[3520:350C][2019-12-07T17:17:42]i100: Detect begin, 26 packages
[3520:350C][2019-12-07T17:17:42]i000: PCRA: Checking running instances.
[3520:350C][2019-12-07T17:17:42]i000: PCRA: Command Action - Install
[3520:350C][2019-12-07T17:17:42]i000: PCRA: Command Display - Full
[3520:350C][2019-12-07T17:17:42]i000: PCRA: No running instances.
[3520:350C][2019-12-07T17:17:42]i000: PCRA: Exiting from prompt.
[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Current Image is not running from a Deployment Image.
[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install
[3520:350C][2019-12-07T17:17:42]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check.
[3520:350C][2019-12-07T17:17:42]i000: Trying to connect to BUDDI, Retry Count = 1. Local Retry Count = 1
[3520:350C][2019-12-07T17:17:48]i000: BeSkipKBCheck :
[3520:350C][2019-12-07T17:17:48]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[3520:350C][2019-12-07T17:17:48]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[3520:350C][2019-12-07T17:17:48]i000: DetectBegin: Installed State of Package DetectedAbsent
[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BentleyAdvisorItInstalledVersion' to value '10.01.00.135'
[3520:2988][2019-12-07T17:17:48]i000: ErrorPage Code: 0
[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.17.010'
[3520:350C][2019-12-07T17:17:48]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{12E5758F-720C-3119-8E7C-6FF83F77BDEC}'
[3520:350C][2019-12-07T17:17:48]i000: Setting numeric variable 'LanguagePackRegistry' to value 0
[3520:350C][2019-12-07T17:17:48]i000: Registry key not found. Key = 'SOFTWARE\Bentley\LumenRT\Bentley LumenRT CONNECT Edition'
[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'NetFramework45Version' to value '461814'
[3520:350C][2019-12-07T17:17:48]i000: Product or related product not found: {1CC0EABA-3397-4893-833E-56BE22820105}
[3520:350C][2019-12-07T17:17:48]i000: Setting numeric variable 'PRODSEARCHITG15INSTALLED' to value 2
[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'
[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90120064-0070-0000-0000-4000000FF1CE}, context: Machine
[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90F60409-7000-11D3-8CFE-0150048383C9}, context: Machine
[3520:350C][2019-12-07T17:17:48]i106: Calculating patch applicability for target product code: {90F60804-7000-11D3-8CFE-0150048383C9}, context: Machine
[3520:350C][2019-12-07T17:17:48]i052: Condition '(NetFramework45Version >= 394802)' evaluates to true.
[3520:350C][2019-12-07T17:17:48]i052: Condition 'VC14_vcredist_x64_Installed' evaluates to true.
[3520:350C][2019-12-07T17:17:48]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.13.17' evaluates to true.
[3520:350C][2019-12-07T17:17:48]i052: Condition 'BentleyAdvisorItInstalledVersion >= v10.1.0.135' evaluates to true.
[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade
[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade
[3520:350C][2019-12-07T17:17:48]w120: Detected partially cached package: DPH, invalid payload: DPH, reason: 0x80070002
[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {0378B8FA-79D8-3736-8168-50A65B8EB857}, scope: PerMachine, version: 10.11.0.4, language: 1033 operation: MinorUpdate
[3520:350C][2019-12-07T17:17:48]i000: DetectRelatedMsiPackage: Operation=MinorUpdate
[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {A73C1780-0589-48DA-956A-20A1FB7C1443}, scope: PerMachine, version: 8.11.8008.0, language: 0 operation: MajorUpgrade
[3520:350C][2019-12-07T17:17:48]i103: Detected related package: {264B522D-1B7F-4AAF-A32B-55A6BF5679F2}, scope: PerMachine, version: 8.11.8004.0, language: 0 operation: MajorUpgrade
[3520:350C][2019-12-07T17:17:48]i052: Condition 'LumenRTInstalledVersion >= v16.12.22.66' evaluates to false.
[3520:350C][2019-12-07T17:17:48]w120: Detected partially cached package: PowerProductLanguagePack, invalid payload: PowerProductLanguagePack, reason: 0x80070570
[3520:350C][2019-12-07T17:17:48]i052: Condition 'LanguagePackRegistry = v10.07.01.011' evaluates to false.
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCore, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCoreKB2803801, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCoreKB2803801 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCoreKB3061498, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCoreKB3061498 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicCorepatch, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicCorepatch target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLang, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLangPackKB2803801, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicLangPackKB2803801 target: {90F60409-7000-11D3-8CFE-0150048383C9}, state: Present
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLang2, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VisualBasicLangPackKB2803801_2, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i105: Detected package: VisualBasicLangPackKB2803801_2 target: {90F60804-7000-11D3-8CFE-0150048383C9}, state: Present
[3520:350C][2019-12-07T17:17:48]i101: Detected package: DotNet452Full, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: VCRedistx64, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: BentleyConnectClient, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: BentleyAdvisor, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: PowerProductPackage, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: OptionalFeature, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: TechPreview, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: assetmanagertoken, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: PPDesktopShortcut, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
[3520:350C][2019-12-07T17:17:48]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
[3520:350C][2019-12-07T17:17:48]i101: Detected package: CivilDesignWorkSpaceBundleModule, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: CNCCBIMCCKBundleModule, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: CNCCBIMWorkSpacesBundleModule, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: PointTools32Extx86, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnIndexer, state: Present, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: DgnThumbnailProvier, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: ItgDgnDbImporter_v2, state: Absent, cached: Complete
[3520:350C][2019-12-07T17:17:48]i101: Detected package: DPH, state: Present, cached: Partial
[3520:350C][2019-12-07T17:17:48]i101: Detected package: LumenRT2017, state: Absent, cached: None
[3520:350C][2019-12-07T17:17:48]i101: Detected package: PowerProductLanguagePack, state: Absent, cached: Partial
[3520:350C][2019-12-07T17:17:48]i000: Detect complete Start
[3520:350C][2019-12-07T17:17:48]i000: Setting string variable 'BePlannedAction' to value 'Install'
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMCCKBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: CNCCBIMWorkSpacesBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnIndexer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DPH AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: PowerProductLanguagePack AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLang2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: DotNet452Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: BentleyAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Install
[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:48]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[3520:350C][2019-12-07T17:17:49]i000: Detection complete planned action: Install
[3520:350C][2019-12-07T17:17:49]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[3520:350C][2019-12-07T17:17:49]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[3520:350C][2019-12-07T17:17:49]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Creating new SessionMutex
[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Creating Mutex with Name={ac65c314-2ade-4fb2-9452-9e2c0d5265af}-InstallMutex
[3520:350C][2019-12-07T17:17:49]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[3520:350C][2019-12-07T17:17:49]i000: WixInstallBA::SilentPlan
[3520:350C][2019-12-07T17:17:49]i000: Checking ADDLOCAL and REMOVE...
[3520:350C][2019-12-07T17:17:49]e000: baApplication_DetectWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg
[3520:350C][2019-12-07T17:17:49]i000: AutoCad Civil 3D ObjectEnabler:Searching
[3520:350C][2019-12-07T17:17:49]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[3520:350C][2019-12-07T17:17:49]e000: baCustomConfigurationPath:Start
[3520:350C][2019-12-07T17:17:49]i199: Detect complete, result: 0x0
[3520:2988][2019-12-07T17:17:51]e000: In Sequence current and the next UI are same, please change the sequence and try again
[3520:2988][2019-12-07T17:17:51]i052: Condition 'NOT BeUpgradingProductCodes' evaluates to true.
[3520:2988][2019-12-07T17:17:55]i000: Setting string variable 'InstallDirectory' to value 'F:\Program Files\Bentley\CNCCBIMOpenRoads\'
[3520:2988][2019-12-07T17:18:01]i000: Setting string variable 'ConfigurationDirectory' to value 'F:\ProgramData\Bentley\CNCCBIMOpenRoads\'
[3520:2988][2019-12-07T17:18:09]i000: WixInstallBA::Plan
[3520:2988][2019-12-07T17:18:09]i000: WixInstallBA::SetupModel Plan
[3520:2988][2019-12-07T17:18:09]i000: SetupModel::Before Plan
[3520:3B90][2019-12-07T17:18:09]i000: Before Plan Async
[3520:3B90][2019-12-07T17:18:09]i000: SetupViewModel::Before Plan
[3520:3B90][2019-12-07T17:18:09]i000: IsAnythingToDownload: Demanded by ItgDgnDbImporter
[3520:3B90][2019-12-07T17:18:09]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1
[3520:3B90][2019-12-07T17:18:09]i000: WixInstallBA::Before Plan Complete
[3520:3B90][2019-12-07T17:18:09]i000: WixInstallBA::Engine Plan
[3520:350C][2019-12-07T17:18:09]i200: Plan begin, 26 packages, action: Install
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'LumenRTInstallDirectory' to value 'C:\Program Files\Bentley\Bentley LumenRT CONNECT Edition - Update 12\'
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: DotNet452Full
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: VCRedistx64
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: BentleyAdvisor
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_ItgDgnDbImporter' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_000_ItgDgnDbImporter.log'
[3520:350C][2019-12-07T17:18:09]i204: Plan 7 msi features for package: PowerProductPackage
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_DefaultFeature_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_OptionalFeature_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: OptionalFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_TechPreview_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: TechPreview, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: assetmanagertoken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_PPDesktopShortcut_IsNotInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: PPDesktopShortcut, state: Absent, default requested: Unknown, ba requested: Absent, execute action: None, rollback action: None
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_Configuration_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: Configuration, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_IsInstalling' to value '1'
[3520:350C][2019-12-07T17:18:09]i203: Planned feature: FileAssociationFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_PowerProductPackage' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_001_PowerProductPackage_rollback.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_PowerProductPackage' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_001_PowerProductPackage.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_002_CivilDesignWorkSpaceBundleModule_rollback.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_002_CivilDesignWorkSpaceBundleModule.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CNCCBIMCCKBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_003_CNCCBIMCCKBundleModule_rollback.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CNCCBIMCCKBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_003_CNCCBIMCCKBundleModule.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_CNCCBIMWorkSpacesBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_004_CNCCBIMWorkSpacesBundleModule_rollback.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_CNCCBIMWorkSpacesBundleModule' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_004_CNCCBIMWorkSpacesBundleModule.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_ItgDgnDbImporter_v2' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_005_ItgDgnDbImporter_v2.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_DPH' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_006_DPH.log'
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: LumenRT2017
[3520:350C][2019-12-07T17:18:09]w321: Skipping dependency registration on package with no dependency providers: PowerProductLanguagePack
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleLog_PowerProductLanguagePack' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_007_PowerProductLanguagePack.log'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'WixBundleRollbackLog_PowerProductLanguagePack' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735_007_PowerProductLanguagePack_rollback.log'
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCore, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCoreKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCoreKB3061498, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicCorepatch, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLang, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLangPackKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLang2, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VisualBasicLangPackKB2803801_2, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: DotNet452Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i201: Planned package: VCRedistx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i201: Planned package: BentleyConnectClient, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i201: Planned package: BentleyAdvisor, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i201: Planned package: ItgDgnDbImporter, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: PowerProductPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: CivilDesignWorkSpaceBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: CNCCBIMCCKBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: CNCCBIMWorkSpacesBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: PointTools32Extx86, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnIFilterSetUpx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnIndexer, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: DgnThumbnailProvier, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: HDRPreviewExtension_x64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: ItgDgnDbImporter_v2, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: DPH, state: Present, default requested: Present, ba requested: Present, execute: MinorUpgrade, rollback: None, cache: Yes, uncache: No, dependency: Register
[3520:350C][2019-12-07T17:18:09]i201: Planned package: LumenRT2017, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i201: Planned package: PowerProductLanguagePack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None
[3520:350C][2019-12-07T17:18:09]i000: GetWindowsRootDriveName (): winRoot=C:\
[3520:350C][2019-12-07T17:18:09]i000: IsPathRooted (C:\): true
[3520:350C][2019-12-07T17:18:09]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=416993192, FileName=G:\CNCCBIM OpenRoads10.07.01.011\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=416993192
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=859677478, NewSize=1276670670
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1276670670
[3520:350C][2019-12-07T17:18:09]i000: IsPathRooted (F:\): true
[3520:350C][2019-12-07T17:18:09]i000: GetDriveName (F:\): DriveInfo.Name=F:\
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): DriveName=F:\, Path=F:\Program Files\Bentley\CNCCBIMOpenRoads\
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Adding DriveName=F:\, Size=4373790661, NewSize=4373790661
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Configurations. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Application Options. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = File association. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Desktop Shortcut. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Technology Preview Features. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature is not a package = Asset Manager. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=394494298, NewSize=1671164968
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1671164968
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=12966717, NewSize=1684131685
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1684131685
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=6363952, NewSize=1690495637
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Pointools32Ext. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN IFilter. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley Dgn Index Service. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Thumbnail Provider. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = HDR Preview. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1690495637
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1688304823, NewSize=3378800460
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Preview Handler. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3378800460
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=0, NewSize=3378800460
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64). Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB2803801). Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB3061498). Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = VBA Patch. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) English. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) Chinese (Simplified). Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.2. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23026. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECTION Client. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECT Advisor. Next
[3520:350C][2019-12-07T17:18:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2005889248, NewSize=5384689708
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive C:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive D:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive E:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive F:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Requested Drive-List contains drive F:\
[3520:350C][2019-12-07T17:18:09]i000: checkInstallSize (): Checking for drive G:\
[3520:350C][2019-12-07T17:18:09]i000: validateInstallSize (): Result=True
[3520:350C][2019-12-07T17:18:09]i000: PlanComplete: Called
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'ItgDgnDbImporter_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_Configuration_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_OptionalFeature_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_TechPreview_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CivilDesignWorkSpaceBundleModule_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CNCCBIMCCKBundleModule_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'CNCCBIMWorkSpacesBundleModule_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PointTools32Extx86_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnIFilterSetUpx64_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnIndexer_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DgnThumbnailProvier_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'HDRPreviewExtension_x64_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'ItgDgnDbImporter_v2_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DPH_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'PowerProductLanguagePack_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCore_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCoreKB2803801_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCoreKB3061498_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicCorepatch_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLang_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLangPackKB2803801_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLang2_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VisualBasicLangPackKB2803801_2_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'DotNet452Full_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'VCRedistx64_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: Setting string variable 'BentleyAdvisor_RequestedState' to value '1'
[3520:350C][2019-12-07T17:18:09]i000: WixInstallBA::Apply
[3520:350C][2019-12-07T17:18:09]i000: WixInstallBA::Engine Apply
[3520:350C][2019-12-07T17:18:09]i299: Plan complete, result: 0x0
[3520:350C][2019-12-07T17:18:09]i300: Apply begin
[3520:2988][2019-12-07T17:18:09]i000: ErrorPage Code: 0
[3520:350C][2019-12-07T17:18:09]i010: Launching elevated engine process.
[3520:350C][2019-12-07T17:18:10]i011: Launched elevated engine process.
[3520:350C][2019-12-07T17:18:11]i012: Connected to elevated engine.
[2718:218C][2019-12-07T17:18:11]i358: Pausing automatic updates.
[2718:218C][2019-12-07T17:18:11]i359: Paused automatic updates.
[2718:218C][2019-12-07T17:18:11]i360: Creating a system restore point.
[2718:218C][2019-12-07T17:18:11]w363: Could not create system restore point, error: 0x80070422. Continuing...
[2718:218C][2019-12-07T17:18:11]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, options: 0x7, disable resume: No
[2718:218C][2019-12-07T17:18:11]i000: Caching bundle from: 'C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\.be\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe' to: 'C:\ProgramData\Package Cache\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_Full.exe'
[2718:218C][2019-12-07T17:18:11]i320: Registering bundle dependency provider: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}, version: 10.7.1.11
[2718:218C][2019-12-07T17:18:11]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: Active, restart initiated: No, disable resume: No
[3520:350C][2019-12-07T17:18:11]i000: Installation chain initiated package from
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, version: 7.1.00.00, package: VisualBasicCore
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, version: (null), package: VisualBasicCoreKB2803801
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, version: (null), package: VisualBasicCoreKB3061498
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, version: (null), package: VisualBasicCorepatch
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, version: (null), package: VisualBasicLangPackKB2803801
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang2
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2
[2718:218C][2019-12-07T17:18:11]i323: Registering package dependency provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, version: (null), package: VisualBasicLangPackKB2803801_2
[2718:218C][2019-12-07T17:18:11]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package: VisualBasicLangPackKB2803801_2
[2718:4434][2019-12-07T17:18:13]i304: Verified existing payload: ItgDgnDbImporter at path: C:\ProgramData\Package Cache\{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}v1.6.7.5\ItgDgnDbImporter_1.6_x64.msi.
[2718:218C][2019-12-07T17:18:13]i323: Registering package dependency provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, version: 1.6.7.5, package: ItgDgnDbImporter
[3520:350C][2019-12-07T17:18:13]i000: Installing ItgDgnDbImporter
[3520:350C][2019-12-07T17:18:13]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;itgdgndbimporter'
[2718:218C][2019-12-07T17:18:13]i301: Applying execute package: ItgDgnDbImporter, action: Install, path: C:\ProgramData\Package Cache\{E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}v1.6.7.5\ItgDgnDbImporter_1.6_x64.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7" PRODITG15INSTALLED="5"'
[2718:4434][2019-12-07T17:18:21]i304: Verified existing payload: PowerProductPackage at path: C:\ProgramData\Package Cache\{D7315727-407E-310A-A598-3517F0DA8659}v10.07.01.011\CNCCBIMOpenRoadsx64.msi.
[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CivilDesignWorkSpaceBundleModule at path: C:\ProgramData\Package Cache\{C3B6626D-1661-3522-AEBA-C94863527F83}v10.07.01.011\CivilDesignWorkSpacex64.msi.
[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CNCCBIMCCKBundleModule at path: C:\ProgramData\Package Cache\{61AF933E-BD4E-316C-9F3A-30CC3605EAFD}v10.07.01.011\CNCCBIMCCKx64.msi.
[2718:4434][2019-12-07T17:18:23]i304: Verified existing payload: CNCCBIMWorkSpacesBundleModule at path: C:\ProgramData\Package Cache\{C0FC36FA-2637-3DB5-80F7-390F839C12DB}v10.07.01.011\CNCCBIMWorkSpacesx64.msi.
[2718:4434][2019-12-07T17:18:25]i304: Verified existing payload: ItgDgnDbImporter_v2 at path: C:\ProgramData\Package Cache\{11A561B0-FC3A-4237-B5E1-D37C3E89641B}v2.0.2.76\ItgDgnDbImporter_2.0_x64.msi.
[3520:0850][2019-12-07T17:18:25]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi
[3520:0850][2019-12-07T17:18:26]i000: Setting string variable 'WixBundleLastUsedSource' to value 'G:\CNCCBIM OpenRoads10.07.01.011\'
[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804
[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Failed to verify hash of payload: DPH
[2718:4434][2019-12-07T17:18:27]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.
[2718:4434][2019-12-07T17:18:27]e000: Error 0x80091007: Failed to cache payload: DPH
[3520:0850][2019-12-07T17:18:27]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 0
[3520:0850][2019-12-07T17:18:27]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.
[3520:0850][2019-12-07T17:18:27]e349: Application requested retry of payload: DPH, encountered error: 0x80091007. Retrying...
[3520:0850][2019-12-07T17:18:27]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi
[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804
[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Failed to verify hash of payload: DPH
[2718:4434][2019-12-07T17:18:29]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.
[2718:4434][2019-12-07T17:18:29]e000: Error 0x80091007: Failed to cache payload: DPH
[3520:0850][2019-12-07T17:18:29]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 1
[3520:0850][2019-12-07T17:18:29]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.
[3520:0850][2019-12-07T17:18:29]e349: Application requested retry of payload: DPH, encountered error: 0x80091007. Retrying...
[3520:0850][2019-12-07T17:18:29]i338: Acquiring package: DPH, payload: DPH, copy from: G:\CNCCBIM OpenRoads10.07.01.011\DgnPreviewHandlerx64.msi
[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Hash mismatch for path: C:\ProgramData\Package Cache\.unverified\DPH, expected: EED153F0EA4789C4A584D11E42B6F4D24E67F21D, actual: E9F3EA2EED43E13B1FAE231B5720B2F3C4A3E804
[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Failed to verify hash of payload: DPH
[2718:4434][2019-12-07T17:18:33]e310: Failed to verify payload: DPH at path: C:\ProgramData\Package Cache\.unverified\DPH, error: 0x80091007. Deleting file.
[2718:4434][2019-12-07T17:18:33]e000: Error 0x80091007: Failed to cache payload: DPH
[3520:0850][2019-12-07T17:18:33]e000: CacheVerifyComplete: Failed with error code -2146889721 and retry number 2
[3520:0850][2019-12-07T17:18:33]e314: Failed to cache payload: DPH from working path: C:\Users\tang\AppData\Local\Temp\{8C5FA3A0-F575-438E-946D-3E95D015C074}\DPH, error: 0x80091007.
[3520:0850][2019-12-07T17:18:33]e000: Caching failed for DPH
[3520:0850][2019-12-07T17:18:33]w350: Applied non-vital package: DPH, encountered error: 0x80091007. Continuing...
[2718:4434][2019-12-07T17:18:35]i304: Verified existing payload: PowerProductLanguagePack at path: C:\ProgramData\Package Cache\B60D36643F452F7A04087854E0CA3C08259E15B9\Setup_CNCCBIMOpenRoadsx64_10.07.01.011_zh-CN_LangPack.exe.
[3520:350C][2019-12-07T17:18:37]i000: Installed package ItgDgnDbImporter
[3520:350C][2019-12-07T17:18:37]i319: Applied execute package: ItgDgnDbImporter, result: 0x0, restart: None
[2718:218C][2019-12-07T17:18:37]i325: Registering dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package: ItgDgnDbImporter
[2718:218C][2019-12-07T17:18:37]i323: Registering package dependency provider: {D7315727-407E-310A-A598-3517F0DA8659}, version: 10.07.01.011, package: PowerProductPackage
[3520:350C][2019-12-07T17:18:37]i000: Installing PowerProductPackage
[3520:350C][2019-12-07T17:18:37]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;itgdgndbimporter;powerproductpackage'
[2718:218C][2019-12-07T17:18:37]i301: Applying execute package: PowerProductPackage, action: Install, path: C:\ProgramData\Package Cache\{D7315727-407E-310A-A598-3517F0DA8659}v10.07.01.011\CNCCBIMOpenRoadsx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLDIR="F:\Program Files\Bentley\CNCCBIMOpenRoads\" PACKAGE_HOMEROOT="F:\ProgramData\Bentley\CNCCBIMOpenRoads\" FROMLAUNCHSETUP="1" WIXUI_SHORTCUTSDIALOGDESKTOPCHECKBOX="" BUNDLEPROVIDERKEY="{ac65c314-2ade-4fb2-9452-9e2c0d5265af}" BE_BUNDLE_NAME="CNCCBIM OpenRoads" BE_BUNDLE_VERSION="10.7.1.11" BE_BUNDLE_BUILDTYPE="Release" BE_BUNDLE_DEPLOYMENTIMAGE_GUID="" USER_CONFIGURATION_LOCATION="" ADDLOCAL="DefaultFeature,OptionalFeature,TechPreview,assetmanagertoken,Configuration,FileAssociationFeature"'
[2718:218C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to install MSI package.
[2718:218C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to execute MSI package.
[3520:350C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[3520:350C][2019-12-07T17:20:12]i000: Installed package PowerProductPackage
[3520:350C][2019-12-07T17:20:12]i319: Applied execute package: PowerProductPackage, result: 0x80070643, restart: None
[3520:350C][2019-12-07T17:20:12]e000: Error 0x80070643: Failed to execute MSI package.
[3520:350C][2019-12-07T17:20:12]i000: Installing PowerProductPackage
[2718:218C][2019-12-07T17:20:12]i318: Skipped rollback of package: PowerProductPackage, action: Uninstall, already: Absent
[3520:350C][2019-12-07T17:20:12]i319: Applied rollback package: PowerProductPackage, result: 0x0, restart: None
[3520:2988][2019-12-07T17:20:12]i000: ErrorPage Code: -2147023293
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {D7315727-407E-310A-A598-3517F0DA8659}, package: PowerProductPackage
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package ItgDgnDbImporter
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {E0BE92C6-B3E1-4072-8D23-5DBD3E303D97}, package: ItgDgnDbImporter
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package VisualBasicLangPackKB2803801_2
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {CEA3AF8C-74FB-4D4A-A011-411054A8F3EE}, package: VisualBasicLangPackKB2803801_2
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang2
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package VisualBasicLangPackKB2803801
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package VisualBasicCorepatch
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package VisualBasicCoreKB3061498
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package VisualBasicCoreKB2803801
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801
[2718:218C][2019-12-07T17:20:12]i326: Removed dependency: {ac65c314-2ade-4fb2-9452-9e2c0d5265af} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package VisualBasicCore
[2718:218C][2019-12-07T17:20:12]i329: Removed package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[3520:350C][2019-12-07T17:20:12]i000: Installation chain finished package from
[2718:218C][2019-12-07T17:20:12]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: None, restart: None, disable resume: No
[2718:218C][2019-12-07T17:20:12]i330: Removed bundle dependency provider: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}
[2718:218C][2019-12-07T17:20:12]i352: Removing cached bundle: {ac65c314-2ade-4fb2-9452-9e2c0d5265af}, from path: C:\ProgramData\Package Cache\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}\
[2718:218C][2019-12-07T17:20:12]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ac65c314-2ade-4fb2-9452-9e2c0d5265af}, resume: None, restart initiated: No, disable resume: No
[3520:350C][2019-12-07T17:20:12]i000: F:\Program Files\Bentley\CNCCBIMOpenRoads\CNCCBIMOpenRoads\ActivationWizard.exe application is set for launch after installation
[3520:350C][2019-12-07T17:20:12]i000: application not found to launch after installation
[3520:350C][2019-12-07T17:20:12]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\tang\AppData\Local\Temp\CNCCBIM_OpenRoads_20191207171735.zip'
[3520:350C][2019-12-07T17:20:12]e000: baApplication_ApplyCompleteWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg
[3520:350C][2019-12-07T17:20:12]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Parents Reply Children
