Context Capture在windows10安装不了,为什么呢
各位老师,
   您们好,请问CC在windows下安装不了,提示如下,
[2598:1DBC][2017-06-16T14:50:02]i001: Burn v3.10.2.2516, Windows v10.0 (Build 15063: Service Pack 0), path: C:\Users\GL\AppData\Local\Temp\{E1B960D1-68D2-47EA-8F7D-79D597100753}\.cr\CC 4-4 (040400338en).exe
[2598:1DBC][2017-06-16T14:50:02]i009: Command Line: '"-burn.clean.room=D:\software\cc4.4\CC 4-4 (040400338en).exe"'
[2598:1DBC][2017-06-16T14:50:02]i000: Setting string variable 'WixBundleOriginalSource' to value 'D:\software\cc4.4\CC 4-4 (040400338en).exe'
[2598:1DBC][2017-06-16T14:50:02]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'D:\software\cc4.4\'
[2598:1DBC][2017-06-16T14:50:02]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\GL\AppData\Local\Temp\ContextCapture_64-bit_20170616145002.log'
[2598:1DBC][2017-06-16T14:50:02]i000: Setting string variable 'WixBundleName' to value 'ContextCapture 64-bit'
[2598:1DBC][2017-06-16T14:50:02]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[2598:2610][2017-06-16T14:50:02]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[2598:2610][2017-06-16T14:50:02]i000: Setting version variable 'WixBundleFileVersion' to value '4.4.0.338'
[2598:1DBC][2017-06-16T14:50:02]i100: Detect begin, 2 packages
[2598:1DBC][2017-06-16T14:50:02]i101: Detected package: vcredist_x64.exe, state: Absent, cached: None
[2598:1DBC][2017-06-16T14:50:02]i101: Detected package: CC_msi, state: Absent, cached: None
[2598:1DBC][2017-06-16T14:50:02]i199: Detect complete, result: 0x0
[2598:2610][2017-06-16T14:50:03]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 0
[2598:1DBC][2017-06-16T14:50:03]i200: Plan begin, 2 packages, action: Install
[2598:1DBC][2017-06-16T14:50:03]w321: Skipping dependency registration on package with no dependency providers: vcredist_x64.exe
[2598:1DBC][2017-06-16T14:50:03]i000: Setting string variable 'WixBundleLog_vcredist_x64.exe' to value 'C:\Users\GL\AppData\Local\Temp\ContextCapture_64-bit_20170616145002_000_vcredist_x64.exe.log'
[2598:1DBC][2017-06-16T14:50:03]i000: Setting string variable 'WixBundleRollbackLog_CC_msi' to value 'C:\Users\GL\AppData\Local\Temp\ContextCapture_64-bit_20170616145002_001_CC_msi_rollback.log'
[2598:1DBC][2017-06-16T14:50:03]i000: Setting string variable 'WixBundleLog_CC_msi' to value 'C:\Users\GL\AppData\Local\Temp\ContextCapture_64-bit_20170616145002_001_CC_msi.log'
[2598:1DBC][2017-06-16T14:50:03]i201: Planned package: vcredist_x64.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[2598:1DBC][2017-06-16T14:50:03]i201: Planned package: CC_msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: Register
[2598:1DBC][2017-06-16T14:50:03]i299: Plan complete, result: 0x0
[2598:1DBC][2017-06-16T14:50:03]i300: Apply begin
[2598:1DBC][2017-06-16T14:50:03]i010: Launching elevated engine process.
[2598:1DBC][2017-06-16T14:50:05]i011: Launched elevated engine process.
[2598:1DBC][2017-06-16T14:50:05]i012: Connected to elevated engine.
[2AB8:164C][2017-06-16T14:50:05]i358: Pausing automatic updates.
[2AB8:164C][2017-06-16T14:50:05]i359: Paused automatic updates.
[2AB8:164C][2017-06-16T14:50:05]i360: Creating a system restore point.
[2AB8:164C][2017-06-16T14:50:05]i361: Created a system restore point.
[2AB8:164C][2017-06-16T14:50:05]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3856bc44-e76b-475c-9184-076c23616f37}, options: 0x7, disable resume: No
[2AB8:164C][2017-06-16T14:50:05]i000: Caching bundle from: 'C:\Users\GL\AppData\Local\Temp\{8C1849A8-DD21-44F7-8D2F-084535C75F8F}\.be\CCDesktop-4.4.0.338.x64-en.exe' to: 'C:\ProgramData\Package Cache\{3856bc44-e76b-475c-9184-076c23616f37}\CCDesktop-4.4.0.338.x64-en.exe'
[2AB8:164C][2017-06-16T14:50:05]i320: Registering bundle dependency provider: {3856bc44-e76b-475c-9184-076c23616f37}, version: 4.4.0.338
[2AB8:164C][2017-06-16T14:50:05]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3856bc44-e76b-475c-9184-076c23616f37}, resume: Active, restart initiated: No, disable resume: No
[2598:2AA4][2017-06-16T14:50:05]i336: Acquiring container: WixAttachedContainer, copy from: D:\software\cc4.4\CC 4-4 (040400338en).exe
[2598:2AA4][2017-06-16T14:50:06]i000: Setting string variable 'WixBundleLastUsedSource' to value 'D:\software\cc4.4\'
[2AB8:1254][2017-06-16T14:50:06]i305: Verified acquired payload: vcredist_x64.exe at path: C:\ProgramData\Package Cache\.unverified\vcredist_x64.exe, moving to: C:\ProgramData\Package Cache\3155CB0F146B927FCC30647C1A904CD162548C8C\Redist\vcredist_x64.exe.
[2AB8:1254][2017-06-16T14:50:07]i305: Verified acquired payload: CC_msi at path: C:\ProgramData\Package Cache\.unverified\CC_msi, moving to: C:\ProgramData\Package Cache\{24E93589-6497-4519-96B3-7EC5BD184AAE}v4.4.0.338\CCDesktop-partial-4.4.0.338.x64-en.msi.
[2AB8:164C][2017-06-16T14:50:07]i301: Applying execute package: vcredist_x64.exe, action: Install, path: C:\ProgramData\Package Cache\3155CB0F146B927FCC30647C1A904CD162548C8C\Redist\vcredist_x64.exe, arguments: '"C:\ProgramData\Package Cache\3155CB0F146B927FCC30647C1A904CD162548C8C\Redist\vcredist_x64.exe" /install /quiet /norestart'
[2598:1DBC][2017-06-16T14:50:07]i319: Applied execute package: vcredist_x64.exe, result: 0x0, restart: None
[2AB8:164C][2017-06-16T14:50:07]i323: Registering package dependency provider: {24E93589-6497-4519-96B3-7EC5BD184AAE}, version: 4.4.0.338, package: CC_msi
[2AB8:164C][2017-06-16T14:50:07]i301: Applying execute package: CC_msi, action: Install, path: C:\ProgramData\Package Cache\{24E93589-6497-4519-96B3-7EC5BD184AAE}v4.4.0.338\CCDesktop-partial-4.4.0.338.x64-en.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[2AB8:164C][2017-06-16T14:50:26]e000: Error 0x80070643: Failed to install MSI package.
[2AB8:164C][2017-06-16T14:50:26]e000: Error 0x80070643: Failed to execute MSI package.
[2598:1DBC][2017-06-16T14:50:26]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[2598:1DBC][2017-06-16T14:50:26]i319: Applied execute package: CC_msi, result: 0x80070643, restart: None
[2598:1DBC][2017-06-16T14:50:26]e000: Error 0x80070643: Failed to execute MSI package.
[2AB8:164C][2017-06-16T14:50:26]i318: Skipped rollback of package: CC_msi, action: Uninstall, already: Absent
[2598:1DBC][2017-06-16T14:50:26]i319: Applied rollback package: CC_msi, result: 0x0, restart: None
[2AB8:164C][2017-06-16T14:50:26]i329: Removed package dependency provider: {24E93589-6497-4519-96B3-7EC5BD184AAE}, package: CC_msi
[2AB8:164C][2017-06-16T14:50:26]i351: Removing cached package: CC_msi, from path: C:\ProgramData\Package Cache\{24E93589-6497-4519-96B3-7EC5BD184AAE}v4.4.0.338\
[2AB8:164C][2017-06-16T14:50:26]i351: Removing cached package: vcredist_x64.exe, from path: C:\ProgramData\Package Cache\3155CB0F146B927FCC30647C1A904CD162548C8C\
[2AB8:164C][2017-06-16T14:50:26]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3856bc44-e76b-475c-9184-076c23616f37}, resume: None, restart: None, disable resume: No
[2AB8:164C][2017-06-16T14:50:26]i330: Removed bundle dependency provider: {3856bc44-e76b-475c-9184-076c23616f37}
[2AB8:164C][2017-06-16T14:50:26]i352: Removing cached bundle: {3856bc44-e76b-475c-9184-076c23616f37}, from path: C:\ProgramData\Package Cache\{3856bc44-e76b-475c-9184-076c23616f37}\
[2AB8:164C][2017-06-16T14:50:26]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3856bc44-e76b-475c-9184-076c23616f37}, resume: None, restart initiated: No, disable resume: No
[2598:1DBC][2017-06-16T14:50:27]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart:  No
