Descartes的中文包的安装问题
Descartes的中文包的安装问题,提示如下
[1298:2980][2016-10-14T19:28:06]i001: Burn v3.10.2.2516, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\ADMINI~1\AppData\Local\Temp\{C9A5ACFB-ECBF-4A94-A4BD-DAA0056B4171}\.cr\dcslp10000048zh.exe
[1298:2980][2016-10-14T19:28:06]i000: Initializing numeric variable 'BeARPDisableRepair' to value '1'
[1298:2980][2016-10-14T19:28:06]i000: Initializing numeric variable 'BeARPDisableModify' to value '1'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BundleCoreProductName' to value 'Bentley Descartes CONNECT Edition'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '65134'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeBuildType' to value 'Release'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeBundleShortName' to value 'DescartesStandAlone'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeVarProductCode_LanguagePackInstaller' to value '{FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}'
[1298:2980][2016-10-14T19:28:06]i000: Initializing string variable 'BeVarProductCode_DgnIndexerLanguagePack' to value '{598497EE-F0FF-3EF1-838D-25FBD4692250}'
[1298:2980][2016-10-14T19:28:06]i009: Command Line: '-burn.clean.room=E:\软件\ksj2016-9-27\dcslp10000048zh.exe'
[1298:2980][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleOriginalSource' to value 'E:\软件\ksj2016-9-27\dcslp10000048zh.exe'
[1298:2980][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'E:\软件\ksj2016-9-27\'
[1298:2980][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Bentley_Descartes_CONNECT_Edition_SChinese-Language_pack_20161014192806.log'
[1298:2980][2016-10-14T19:28:06]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[1298:2980][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleName' to value 'Bentley Descartes CONNECT Edition SChinese-Language pack'
[1298:2980][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[1298:2980][2016-10-14T19:28:06]i000: Loading managed bootstrapper application.
[1298:2980][2016-10-14T19:28:06]i000: Creating BA thread to run asynchronously.
[1298:2388][2016-10-14T19:28:06]i000: BentleyBundle Version 10.01.00.13
[1298:2388][2016-10-14T19:28:06]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Administrator\AppData\Local\Temp\{313D89E5-031F-4ED0-A091-CCF40613CA98}\.ba'
[1298:2388][2016-10-14T19:28:06]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Administrator\AppData\Local\Temp\{C9A5ACFB-ECBF-4A94-A4BD-DAA0056B4171}\.cr'
[1298:2388][2016-10-14T19:28:06]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'E:\软件\ksj2016-9-27\'
[1298:2388][2016-10-14T19:28:06]e000: Using Layout File : C:\Users\Administrator\AppData\Local\Temp\{313D89E5-031F-4ED0-A091-CCF40613CA98}\.ba\Setup.lyt
[1298:2388][2016-10-14T19:28:07]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\Bentley Descartes CONNECT Edition SChinese-Language pack\'
[1298:2388][2016-10-14T19:28:07]i000: VisualBasicLang2StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Unknown
[1298:2388][2016-10-14T19:28:07]i000: VisualBasicLang2 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: VisualBasicLang2 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: BentleyConnectClientLPStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: BentleyConnectClientLPAnalyzeFeatureConditions: LaunchAction=Unknown
[1298:2388][2016-10-14T19:28:07]i000: BentleyConnectClientLPAnalyzeFeatureConditions: Condition=BentleyConnectInstalledVersion = v10.0.4.24
[1298:2388][2016-10-14T19:28:07]i052: Condition 'BentleyConnectInstalledVersion = v10.0.4.24' evaluates to false.
[1298:2388][2016-10-14T19:28:07]i000: BentleyConnectClientLPCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: LanguagePackInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: LanguagePackInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
[1298:2388][2016-10-14T19:28:07]i000: LanguagePackInstaller RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: LanguagePackInstaller RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: DgnIndexerLanguagePackStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: DgnIndexerLanguagePackAnalyzeFeatureConditions: LaunchAction=Unknown
[1298:2388][2016-10-14T19:28:07]i000: DgnIndexerLanguagePack RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: DgnIndexerLanguagePack RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2388][2016-10-14T19:28:07]i000: Display is set to Full
[1298:2388][2016-10-14T19:28:07]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeLanguagePackUserControl.xaml
[1298:2388][2016-10-14T19:28:07]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[1298:2388][2016-10-14T19:28:07]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[1298:2388][2016-10-14T19:28:07]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[1298:2388][2016-10-14T19:28:07]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[1298:2980][2016-10-14T19:28:07]i100: Detect begin, 4 packages
[1298:2980][2016-10-14T19:28:07]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[1298:2980][2016-10-14T19:28:07]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[1298:2980][2016-10-14T19:28:07]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[1298:2980][2016-10-14T19:28:07]i000: DetectBegin: Installed State of Package DetectedAbsent
[1298:2980][2016-10-14T19:28:07]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.06.034'
[1298:2980][2016-10-14T19:28:07]i102: Detected related bundle: {9f6f5128-7687-421a-a39d-8bda823b0084}, type: Dependent, scope: PerMachine, version: 10.0.0.43, operation: None
[1298:2980][2016-10-14T19:28:07]i000: Upgrading: RelatedOperation=None; RelationType=Dependent
[1298:2980][2016-10-14T19:28:07]i000: ReferenceId [VBA_LANGUAGE_PRGID]=65134
[1298:2980][2016-10-14T19:28:07]i101: Detected package: VisualBasicLang2, state: Present, cached: Complete
[1298:2980][2016-10-14T19:28:07]i101: Detected package: BentleyConnectClientLP, state: Absent, cached: Complete
[1298:2980][2016-10-14T19:28:07]i101: Detected package: LanguagePackInstaller, state: Absent, cached: None
[1298:2980][2016-10-14T19:28:07]i101: Detected package: DgnIndexerLanguagePack, state: Present, cached: Complete
[1298:2980][2016-10-14T19:28:07]i000: Setting string variable 'BePlannedAction' to value 'Install'
[1298:2980][2016-10-14T19:28:07]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Install
[1298:2980][2016-10-14T19:28:07]i000: VisualBasicLang2 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: VisualBasicLang2 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: BentleyConnectClientLPAnalyzeFeatureConditions: LaunchAction=Install
[1298:2980][2016-10-14T19:28:07]i000: BentleyConnectClientLPAnalyzeFeatureConditions: Condition=BentleyConnectInstalledVersion = v10.0.4.24
[1298:2980][2016-10-14T19:28:07]i052: Condition 'BentleyConnectInstalledVersion = v10.0.4.24' evaluates to false.
[1298:2980][2016-10-14T19:28:07]i000: BentleyConnectClientLPStoreFeatureState: Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: BentleyConnectClientLPCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: LanguagePackInstallerAnalyzeFeatureConditions: LaunchAction=Install
[1298:2980][2016-10-14T19:28:07]i000: LanguagePackInstaller RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: LanguagePackInstaller RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: DgnIndexerLanguagePackAnalyzeFeatureConditions: LaunchAction=Install
[1298:2980][2016-10-14T19:28:07]i000: DgnIndexerLanguagePack RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: DgnIndexerLanguagePack RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[1298:2980][2016-10-14T19:28:07]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[1298:2980][2016-10-14T19:28:07]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=True, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[1298:2980][2016-10-14T19:28:07]i000: CheckForAddOnRelatedBundle (): RELATED {9f6f5128-7687-421a-a39d-8bda823b0084} Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[1298:2980][2016-10-14T19:28:07]i000: GetUpgradeCodes (): ProviderKey={9f6f5128-7687-421a-a39d-8bda823b0084}, CodeType=BundleUpgradeCode
[1298:2980][2016-10-14T19:28:07]i000: CheckForAddOnRelatedBundle (): Product to AddOn found
[1298:2980][2016-10-14T19:28:07]i000: SessionMutex: Creating new SessionMutex
[1298:2980][2016-10-14T19:28:07]i000: SessionMutex: Creating Mutex with Name={a017b293-2429-4ed9-88d9-3e6c353090fb}-InstallMutex
[1298:2980][2016-10-14T19:28:07]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[1298:2980][2016-10-14T19:28:07]i000: WixInstallBA::SilentPlan
[1298:2980][2016-10-14T19:28:07]i199: Detect complete, result: 0x0
[1298:2388][2016-10-14T19:28:09]i000: WixInstallBA::Plan
[1298:2388][2016-10-14T19:28:09]i000: WixInstallBA::SetupModel Plan
[1298:2388][2016-10-14T19:28:09]i000: SetupModel::Before Plan
[1298:0994][2016-10-14T19:28:09]i000: Before Plan Async
[1298:0994][2016-10-14T19:28:09]i000: SetupViewModel::Before Plan
[1298:0994][2016-10-14T19:28:09]i000: WixInstallBA::Before Plan Complete
[1298:0994][2016-10-14T19:28:09]i000: WixInstallBA::Engine Plan
[1298:2980][2016-10-14T19:28:09]i200: Plan begin, 4 packages, action: Install
[1298:2980][2016-10-14T19:28:09]i000: PlanRelatedBundle (): Command line Action for Planning, Id={9f6f5128-7687-421a-a39d-8bda823b0084}, Action=Install
[1298:2980][2016-10-14T19:28:09]i052: Condition 'BentleyConnectInstalledVersion = v10.0.4.24' evaluates to false.
[1298:2980][2016-10-14T19:28:09]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClientLP
[1298:2980][2016-10-14T19:28:09]i000: Setting string variable 'WixBundleRollbackLog_LanguagePackInstaller' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Bentley_Descartes_CONNECT_Edition_SChinese-Language_pack_20161014192806_000_LanguagePackInstaller_rollback.log'
[1298:2980][2016-10-14T19:28:09]i000: Setting string variable 'WixBundleLog_LanguagePackInstaller' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Bentley_Descartes_CONNECT_Edition_SChinese-Language_pack_20161014192806_000_LanguagePackInstaller.log'
[1298:2980][2016-10-14T19:28:09]i201: Planned package: VisualBasicLang2, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[1298:2980][2016-10-14T19:28:09]i201: Planned package: BentleyConnectClientLP, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: Yes, dependency: None
[1298:2980][2016-10-14T19:28:09]i201: Planned package: LanguagePackInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[1298:2980][2016-10-14T19:28:09]i201: Planned package: DgnIndexerLanguagePack, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[1298:2980][2016-10-14T19:28:09]i207: Planned related bundle: {9f6f5128-7687-421a-a39d-8bda823b0084}, type: Dependent, default requested: None, ba requested: None, execute: None, rollback: None, dependency: None
[1298:2980][2016-10-14T19:28:09]i000: GetWindowsRootDriveName (): winRoot=C:\
[1298:2980][2016-10-14T19:28:09]i000: IsPathRooted (C:\): true
[1298:2980][2016-10-14T19:28:09]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=14201976, FileName=E:\软件\ksj2016-9-27\dcslp10000048zh.exe
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) Chinese (Simplified). Next
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=14201976
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1665296, NewSize=15867272
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=15867272
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=34979979, NewSize=50847251
[1298:2980][2016-10-14T19:28:09]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley Dgn Index Service SChinese-Language Pack. Next
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Checking for drive C:\
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Checking for drive D:\
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Checking for drive E:\
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Checking for drive F:\
[1298:2980][2016-10-14T19:28:09]i000: checkInstallSize (): Checking for drive G:\
[1298:2980][2016-10-14T19:28:09]i000: validateInstallSize (): Result=True
[1298:2980][2016-10-14T19:28:09]i000: PlanComplete: Called
[1298:2980][2016-10-14T19:28:09]i000: Setting string variable 'VisualBasicLang2_RequestedState' to value '1'
[1298:2980][2016-10-14T19:28:09]i000: Setting string variable 'LanguagePackInstaller_RequestedState' to value '1'
[1298:2980][2016-10-14T19:28:09]i000: Setting string variable 'DgnIndexerLanguagePack_RequestedState' to value '1'
[1298:2980][2016-10-14T19:28:09]i000: WixInstallBA::Apply
[1298:2980][2016-10-14T19:28:09]i000: WixInstallBA::Engine Apply
[1298:2980][2016-10-14T19:28:09]i299: Plan complete, result: 0x0
[1298:2980][2016-10-14T19:28:09]i300: Apply begin
[1298:2980][2016-10-14T19:28:09]i000: DisplayMessage (正在安装 Bentley Descartes CONNECT Edition SChinese-Language pack)
[1298:2980][2016-10-14T19:28:09]i010: Launching elevated engine process.
[1298:2980][2016-10-14T19:28:09]i011: Launched elevated engine process.
[1298:2980][2016-10-14T19:28:10]i012: Connected to elevated engine.
[158C:1808][2016-10-14T19:28:10]i358: Pausing automatic updates.
[158C:1808][2016-10-14T19:28:10]i359: Paused automatic updates.
[158C:1808][2016-10-14T19:28:10]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{a017b293-2429-4ed9-88d9-3e6c353090fb}, options: 0x7, disable resume: No
[158C:1808][2016-10-14T19:28:10]i000: Caching bundle from: 'C:\Users\ADMINI~1\AppData\Local\Temp\{313D89E5-031F-4ED0-A091-CCF40613CA98}\.be\Setup_DescartesStandAlonex64_10.00.00.048_zh-CN_LangPack.exe' to: 'C:\ProgramData\Package Cache\{a017b293-2429-4ed9-88d9-3e6c353090fb}\Setup_DescartesStandAlonex64_10.00.00.048_zh-CN_LangPack.exe'
[158C:1808][2016-10-14T19:28:10]i320: Registering bundle dependency provider: {a017b293-2429-4ed9-88d9-3e6c353090fb}, version: 10.0.0.48
[158C:1808][2016-10-14T19:28:10]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{a017b293-2429-4ed9-88d9-3e6c353090fb}, resume: Active, restart initiated: No, disable resume: No
[1298:2980][2016-10-14T19:28:10]i000: Installation chain initiated package from
[158C:1808][2016-10-14T19:28:10]i323: Registering package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang2
[1298:2AF0][2016-10-14T19:28:10]i336: Acquiring container: WixAttachedContainer, copy from: E:\软件\ksj2016-9-27\dcslp10000048zh.exe
[158C:1808][2016-10-14T19:28:10]i325: Registering dependency: {a017b293-2429-4ed9-88d9-3e6c353090fb} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2
[1298:2AF0][2016-10-14T19:28:10]i000: Setting string variable 'WixBundleLastUsedSource' to value 'E:\软件\ksj2016-9-27\'
[158C:2A88][2016-10-14T19:28:10]i305: Verified acquired payload: LanguagePackInstaller at path: C:\ProgramData\Package Cache\.unverified\LanguagePackInstaller, moving to: C:\ProgramData\Package Cache\{FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}v10.00.00.048\DescartesStandAlonex64_zh-CN.msi.
[158C:1808][2016-10-14T19:28:10]i323: Registering package dependency provider: {FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}, version: 10.00.00.048, package: LanguagePackInstaller
[1298:2980][2016-10-14T19:28:10]i000: Installing LanguagePackInstaller
[1298:2980][2016-10-14T19:28:10]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;languagepackinstaller'
[158C:1808][2016-10-14T19:28:10]i301: Applying execute package: LanguagePackInstaller, action: Install, path: C:\ProgramData\Package Cache\{FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}v10.00.00.048\DescartesStandAlonex64_zh-CN.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" DEFAULT_LANGUAGE_PACK=""'
[158C:1808][2016-10-14T19:28:10]e000: Error 0x80070643: Failed to install MSI package.
[158C:1808][2016-10-14T19:28:10]e000: Error 0x80070643: Failed to execute MSI package.
[1298:2980][2016-10-14T19:28:10]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1298:2980][2016-10-14T19:28:10]i000: Installed package LanguagePackInstaller
[1298:2980][2016-10-14T19:28:10]i000: DisplayMessage (安装失败,错误代码 0x80070643。)
[1298:2980][2016-10-14T19:28:10]i000: DisplayMessage (安装 Bentley Descartes CONNECT Edition SChinese-Language Pack 失败,错误代码为 0x80070643. 安装时发生严重错误)
[1298:2980][2016-10-14T19:28:10]i319: Applied execute package: LanguagePackInstaller, result: 0x80070643, restart: None
[1298:2980][2016-10-14T19:28:10]e000: Error 0x80070643: Failed to execute MSI package.
[158C:1808][2016-10-14T19:28:10]i318: Skipped rollback of package: LanguagePackInstaller, action: Uninstall, already: Absent
[1298:2980][2016-10-14T19:28:10]i319: Applied rollback package: LanguagePackInstaller, result: 0x0, restart: None
[158C:1808][2016-10-14T19:28:10]i329: Removed package dependency provider: {FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}, package: LanguagePackInstaller
[158C:1808][2016-10-14T19:28:10]i351: Removing cached package: LanguagePackInstaller, from path: C:\ProgramData\Package Cache\{FB12B1B1-3F4C-3E93-8B90-AA52C64A73C8}v10.00.00.048\
[158C:1808][2016-10-14T19:28:10]i326: Removed dependency: {a017b293-2429-4ed9-88d9-3e6c353090fb} on package provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang2
[158C:1808][2016-10-14T19:28:10]i329: Removed package dependency provider: {90F60804-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang2
[1298:2980][2016-10-14T19:28:10]i000: Installation chain finished package from
[158C:1808][2016-10-14T19:28:10]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{a017b293-2429-4ed9-88d9-3e6c353090fb}, resume: None, restart: None, disable resume: No
[158C:1808][2016-10-14T19:28:10]i330: Removed bundle dependency provider: {a017b293-2429-4ed9-88d9-3e6c353090fb}
[158C:1808][2016-10-14T19:28:10]i352: Removing cached bundle: {a017b293-2429-4ed9-88d9-3e6c353090fb}, from path: C:\ProgramData\Package Cache\{a017b293-2429-4ed9-88d9-3e6c353090fb}\
[158C:1808][2016-10-14T19:28:10]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{a017b293-2429-4ed9-88d9-3e6c353090fb}, resume: None, restart initiated: No, disable resume: No
[1298:2980][2016-10-14T19:28:10]i000: No application is set for launch after installation
[1298:2980][2016-10-14T19:28:10]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\Administrator\AppData\Local\Temp\Bentley_Descartes_CONNECT_Edition_SChinese-Language_pack_20161014192806.zip'
[1298:2980][2016-10-14T19:28:10]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
