Exception 0x80131501 at 周六 3月 04 10:42:23 2023 Bentley.Licensing.LicenseTool version 11.01.01.07 Windows x64 Crash Report Data: Exception: 'XamlParseException' Report File Name: 'C:\ProgramData\Bentley\Bentley\CrashReports\20230304T104223.222\Exception.log' Exception Message: '对类型“Bentley.Licensing.LicenseTool.Services.ResourceLocator”的构造函数执行符合指定的绑定约束的调用时引发了异常。' Exception Details (Full): System.Windows.Markup.XamlParseException: 对类型“Bentley.Licensing.LicenseTool.Services.ResourceLocator”的构造函数执行符合指定的绑定约束的调用时引发了异常。 ---> System.Exception: Failed to get API Service Client! 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.GetAPIServiceClient_Base() 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning2() 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning() 在 Bentley.Licensing.LicenseTool.LicenseEvents.LicenseEventReceiver..ctor() 在 Bentley.Licensing.LicenseTool.Services.ResourceLocator..ctor() --- 内部异常堆栈跟踪的结尾 --- 在 System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri) 在 System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) 在 System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) 在 System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) 在 System.Windows.Application.LoadBamlStreamWithSyncInfo(Stream stream, ParserContext pc) 在 System.Windows.Application.DoStartup() 在 System.Windows.Application.<.ctor>b__1_0(Object unused) 在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) 在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) 在 System.Windows.Threading.DispatcherOperation.InvokeImpl() 在 MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) 在 System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) 在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) 在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) 在 MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) 在 System.Windows.Threading.DispatcherOperation.Invoke() 在 System.Windows.Threading.Dispatcher.ProcessQueue() 在 System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) 在 MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) 在 MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) 在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) 在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) 在 System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) 在 MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) 在 MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) 在 System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) 在 System.Windows.Application.RunDispatcher(Object ignore) 在 System.Windows.Application.RunInternal(Window window) 在 Bentley.Licensing.LicenseTool.App.Main() System.Exception: Failed to get API Service Client! 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.GetAPIServiceClient_Base() 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning2() 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning() 在 Bentley.Licensing.LicenseTool.LicenseEvents.LicenseEventReceiver..ctor() 在 Bentley.Licensing.LicenseTool.Services.ResourceLocator..ctor() Managed Call Stack: 0: 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.GetAPIServiceClient_Base() 1: 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning2() 2: 在 Bentley.Licensing.Client.API.V1.ServiceClientAPI.IsRunning() 3: 在 Bentley.Licensing.LicenseTool.LicenseEvents.LicenseEventReceiver..ctor() 4: 在 Bentley.Licensing.LicenseTool.Services.ResourceLocator..ctor() 5: 在 System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri) 6: 在 System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) 7: 在 System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) 8: 在 System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) 9: 在 System.Windows.Application.LoadBamlStreamWithSyncInfo(Stream stream, ParserContext pc) 10: 在 System.Windows.Application.DoStartup() 11: 在 System.Windows.Application.<.ctor>b__1_0(Object unused) 12: 在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) 13: 在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) 14: 在 System.Windows.Threading.DispatcherOperation.InvokeImpl() 15: 在 MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) 16: 在 System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) 17: 在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) 18: 在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) 19: 在 MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) 20: 在 System.Windows.Threading.DispatcherOperation.Invoke() 21: 在 System.Windows.Threading.Dispatcher.ProcessQueue() 22: 在 System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) 23: 在 MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) 24: 在 MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) 25: 在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) 26: 在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) 27: 在 System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) 28: 在 MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) 29: 在 MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) 30: 在 System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) 31: 在 System.Windows.Application.RunDispatcher(Object ignore) 32: 在 System.Windows.Application.RunInternal(Window window) 33: 在 Bentley.Licensing.LicenseTool.App.Main() Process Information: PROCESS NAME Bentley.Licensing.LicenseTool.exe PROCESS ID 16804 PROCESS ARCHITECTURE 64-bit MACHINE NAME DESKTOP-T4DVA26 MACHINE LOCALE Chinese (Simplified, China) LOCALE NAME zh-CN OS VERSION Microsoft Windows NT 6.2.9200.0 OS ARCHITECTURE 64-bit RUNTIME VER 4.0.30319.42000 WORKING MEM 67334144 PROCESSOR COUNT 64 WINDOWS USERNAME hp Environment variable list: 1. SYSTEMDRIVE=C: 2. GLODON_COMMON_DOCUMENT=C:\Users\Public\Documents 3. PROGRAMW6432=C:\Program Files 4. CHOCOLATEYINSTALL=C:\ProgramData\chocolatey 5. PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 85 Stepping 4, GenuineIntel 6. ONLINESERVICES=Online Services 7. PROCESSOR_ARCHITECTURE=AMD64 8. PATH=D:\supermap\supermap-iserver-10.0.1-win64-zip\webapps\iserver\WEB-INF\lib;D:\software\hadoop-2.8.2\bin;D:\software\java1.8\bin;D:\software\java1.8\jre\bin;D:\software\nodejs\node_global\node_modules;D:\software\nodejs\node_global;D:\software\apache-maven-3.6.3\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;c:\Program Files (x86)\HP\HP Performance Advisor;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Common Files\Autodesk Shared\;D:\mysql\mysql-8.0.29-winx64\bin;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\DTS\Binn\;E:\SVN\bin;C:\Program Files\Git\cmd;D:\software\nodejs\;C:\ProgramData\chocolatey\bin;D:\hole\nginx-1.23.1;C:\Users\hp\AppData\Local\Microsoft\WindowsApps;C:\Users\hp\.dotnet\tools;C:\Users\hp\AppData\Local\Programs\Microsoft VS Code\bin;D:\PyCharm Community Edition 2022.2.1\bin;E:\idea\IntelliJ IDEA 2022.2.3\bin;C:\Users\hp\AppData\Roaming\npm 9. PYCHARM COMMUNITY EDITION=D:\PyCharm Community Edition 2022.2.1\bin; 10. HOMEPATH=\Users\hp 11. GLODON_COMMON_DESKTOP=C:\Users\Public\Desktop 12. GLODON_COMMON_APPDATA=C:\ProgramData 13. PROCESSOR_REVISION=5504 14. AGSDESKTOPJAVA=C:\Program Files (x86)\ArcGIS\Desktop10.2\ 15. GLODON_PROGRAM_FILES_64=C:\Program Files 16. TEMP=C:\Users\hp\AppData\Local\Temp 17. USERPROFILE=C:\Users\hp 18. LOGONSERVER=\\DESKTOP-T4DVA26 19. USERNAME=hp 20. SYSTEMROOT=C:\WINDOWS 21. GLODON_SYSTEM_DRIVE=C: 22. VS150PROCOMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\Tools\ 23. GLODON_COMMON_FILES_32=C:\Program Files (x86)\Common Files 24. GLODON_WINDOWS_DIR=C:\WINDOWS 25. COMMONPROGRAMFILES=C:\Program Files\Common Files 26. PROGRAMFILES(X86)=C:\Program Files (x86) 27. JAVA_HOME=D:\software\java1.8 28. PROCESSOR_LEVEL=6 29. PROGRAMDATA=C:\ProgramData 30. PLATFORMCODE=5X 31. INTELLIJ IDEA=E:\idea\IntelliJ IDEA 2022.2.3\bin; 32. CSD_PATH=C:\Program Files\KSJ\CivilStationDesigner OpenRail\ 33. ORD_PATH=C:\Program Files\Bentley\OpenRail Designer CONNECT Edition\OpenRailDesigner\ 34. USERDOMAIN=DESKTOP-T4DVA26 35. CHOCOLATEYLASTPATHUPDATE=133102074175162914 36. COMMONPROGRAMW6432=C:\Program Files\Common Files 37. TMP=C:\Users\hp\AppData\Local\Temp 38. MAVEN_HOME=D:\software\apache-maven-3.6.3 39. GLODON_SYSTEM_32=C:\WINDOWS\SysWOW64 40. DRIVERDATA=C:\Windows\System32\Drivers\DriverData 41. HOMEDRIVE=C: 42. WINDIR=C:\WINDOWS 43. CLASSPATH=D:\software\hadoop-2.8.2\bin\winutils.exe 44. NUMBER_OF_PROCESSORS=64 45. OS=Windows_NT 46. NODE_PATH=D:\software\nodejs\node_global\node_modules 47. PROGRAMFILES=C:\Program Files 48. COMSPEC=C:\WINDOWS\system32\cmd.exe 49. USERDOMAIN_ROAMINGPROFILE=DESKTOP-T4DVA26 50. PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC 51. HADOOP_HOME=D:\software\hadoop-2.8.2 52. PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules;c:\Program Files\Intel\Wired Networking\;C:\Program Files (x86)\Microsoft SQL Server\150\Tools\PowerShell\Modules\ 53. APPDATA=C:\Users\hp\AppData\Roaming 54. ONEDRIVE=C:\Users\hp\OneDrive 55. COMPUTERNAME=DESKTOP-T4DVA26 56. GLODON_COMMON_FILES_64=C:\Program Files\Common Files 57. LOCALAPPDATA=C:\Users\hp\AppData\Local 58. ALLUSERSPROFILE=C:\ProgramData 59. COMMONPROGRAMFILES(X86)=C:\Program Files (x86)\Common Files 60. GLODON_SYSTEM_64=C:\WINDOWS\system32 61. REGIONCODE=XXX 62. PUBLIC=C:\Users\Public 63. GLODON_PROGRAM_FILES_32=C:\Program Files (x86) Memory Statistics for process 16804: 130771 MB Total Phys 120823 MB Avail Phys 261843 MB Total Page File 250035 MB Avail Page File 134217727 MB Total Virtual 134212868 MB Avail Virtual 0 MB Avail Extended Virtual Loaded DLLs: NAME VERSION PATH mscorlib 4.8.4510.0 built by: NET48REL1LAST_B C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll Bentley.Licensing.LicenseTool 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.LicenseTool.exe PresentationFramework 4.8.4470.0 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll WindowsBase 4.8.4470.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll System.Core 4.8.4470.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll System 4.8.4488.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll PresentationCore 4.8.4470.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll System.Xaml 4.8.4470.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll System.Configuration 4.8.4190.0 built by: NET48REL1LAST_B C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll System.Xml 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll Bentley.Licensing.LicenseTool.resources 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\zh-CN\Bentley.Licensing.LicenseTool.resources.DLL Telerik.Windows.Themes.VisualStudio2013 2017.2.1717.40 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Telerik.Windows.Themes.VisualStudio2013.DLL Telerik.Windows.Controls 2017.2.1717.45 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Telerik.Windows.Controls.DLL Telerik.Windows.Controls.GridView 2017.2.1717.45 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Telerik.Windows.Controls.GridView.DLL Telerik.Windows.Data 2017.2.1717.45 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Telerik.Windows.Data.DLL Telerik.Windows.Controls.Input 2017.2.1717.45 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Telerik.Windows.Controls.Input.DLL Telerik.Windows.Controls.resources 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\zh-CN\Telerik.Windows.Controls.resources.DLL GalaSoft.MvvmLight 5.2.0.37222 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\GalaSoft.MvvmLight.DLL System.Runtime 4.8.4084.0 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.dll System.ObjectModel 4.8.4084.0 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ObjectModel\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.ObjectModel.dll Bentley.Licensing.Common 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.Common.DLL Serilog 2.7.1.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Serilog.DLL Common.Logging 3.4.1.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Common.Logging.DLL Common.Logging.Core 3.4.1.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Common.Logging.Core.DLL Bentley.Cloud.ThickClient 2022.7.25.1 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Cloud.ThickClient.DLL Bentley.Discovery.Buddi.Client 2020.8.13.4 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Discovery.Buddi.Client.DLL Serilog.Enrichers.Thread 3.1.0.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Serilog.Enrichers.Thread.DLL Serilog.Sinks.PersistentFile 4.1.0.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Serilog.Sinks.PersistentFile.DLL System.Windows.Forms 4.8.4488.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll System.Drawing 4.8.4390.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll mscorlib.resources 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\mscorlib.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\mscorlib.resources.dll Common.Logging.Serilog 4.4.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Common.Logging.Serilog.DLL Autofac 3.5.2.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Autofac.DLL Bentley.Licensing.Client.API 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.Client.API.DLL Microsoft.Practices.ServiceLocation 1.3.0.0 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Microsoft.Practices.ServiceLocation.DLL Bentley.Licensing.ServiceInterface 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.ServiceInterface.DLL System.Runtime.Caching 4.8.4084.0 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Caching\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.Caching.dll System.ServiceModel 4.8.4455.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel\v4.0_4.0.0.0__b77a5c561934e089\System.ServiceModel.dll System.Runtime.Serialization 4.8.4455.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll SMDiagnostics 4.8.4455.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\SMDiagnostics\v4.0_4.0.0.0__b77a5c561934e089\SMDiagnostics.dll System.ServiceModel.Internals 4.8.4455.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Internals\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Internals.dll System.IdentityModel 4.8.4455.0 built by: NET48REL1LAST_C C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IdentityModel\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.dll System.IdentityModel.Selectors 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IdentityModel.Selectors\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.Selectors.dll System.ServiceModel.resources 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\System.ServiceModel.resources.dll System.Net.Http 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Net.Http\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.Http.dll System.resources 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\System.resources.dll System.Xaml.resources 4.8.4084.0 built by: NET48REL1 C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xaml.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\System.Xaml.resources.dll Bentley.Licensing.LicenseManagement 11.01.01.07 C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService\Bentley.Licensing.LicenseManagement.DLL
从您这个Log文件中能看出来您目前使用的.NET Framework是4.8,目前MS要求的是4.6.2。请安装4.6.2后看是否能顺利启动。
【注】:在安装有高版本.NET的情况下,下载.NET的低版本的Developer Pack可以安装上低版本的.NET
账号应该没有问题 在其他设备上可以正常使用 4.6.2也已安装,还是没解决这个问题
该提示不代表您电脑中安装了.NET4.6.2,而是说你电脑中有更高的版本了。请到控制面板中检查一下是否确实存在。如下图所示:
再次强调一下,一定要下载微软的.NET的Developer Pack才能在安装有高版本.NET的机器上安装低版本的.NET的。
还有一点,对比一下正常的电脑上安装的软件,看是否您这台电脑上安装有某款软件导致了冲突。比如PKPM的某个插件就会导致这种情况的发生。
这个我也不知道是什么问题 授权部门的工程师帮忙解决了 应该是删除了注册表后重置了一下
解决了就好。
