,或者是否有其他方式可以获得中文的说明文档?我安装的安装包为MS U13-10.13.01.001,语言包为mslp10130048zh_updt13,提示不匹配该如何解决?
[35B0:2BA8][2020-07-30T12:12:42]i001: Burn v3.11.1.2318, Windows v10.0 (Build 15063: Service Pack 0), path: C:\Windows\Temp\{93BDDC41-0DED-473C-BC6D-E7C4C3A37022}\.cr\mslp10130048zh_updt13.exe [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing numeric variable 'BeARPDisableRepair' to value '1' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing numeric variable 'BeARPDisableModify' to value '1' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BundleCoreProductName' to value 'MicroStation CONNECT Edition' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeBuildType' to value 'Release' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeNotBuildType' to value 'Beta' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeWin64Bundle' to value 'yes' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing numeric variable 'BeUpdateNumber' to value '13' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '65134' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_LanguagePackInstaller' to value '{E5E7FC76-68F0-3247-8E6A-7FEF75ECBD02}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_LanguagePackInstaller' to value '{E5E7FC76-68F0-3247-8E6A-7FEF75ECBD02}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_VisualizationBundleModule_langpack' to value '{069D5D8A-5E7E-3221-8164-7F36BC856C66}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_VisualizationBundleModule_langpack' to value '{069D5D8A-5E7E-3221-8164-7F36BC856C66}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_DescartesBundleModule_langpack' to value '{D987F46C-A400-381B-9CD8-89FE829BCCCF}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_DescartesBundleModule_langpack' to value '{D987F46C-A400-381B-9CD8-89FE829BCCCF}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang2' to value '{90F60804-7000-11D3-8CFE-0150048383C9}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_DgnIndexerLanguagePack' to value '{598497EE-F0FF-3EF1-838D-25FBD4692250}' [35B0:2BA8][2020-07-30T12:12:42]i000: Initializing string variable 'BeVarProductCode_DgnIndexerLanguagePack' to value '{598497EE-F0FF-3EF1-838D-25FBD4692250}' [35B0:2BA8][2020-07-30T12:12:42]i009: Command Line: '-burn.clean.room=D:\2020Y\03Bentley\MS\MS13\mslp10130048zh_updt13.exe -burn.filehandle.attached=528 -burn.filehandle.self=536' [35B0:2BA8][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleOriginalSource' to value 'D:\2020Y\03Bentley\MS\MS13\mslp10130048zh_updt13.exe' [35B0:2BA8][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'D:\2020Y\03Bentley\MS\MS13\' [35B0:2BA8][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\MicroStation_CONNECT_Edition_SChinese-Language_pack_20200730121242.log' [35B0:2BA8][2020-07-30T12:12:42]i052: Condition 'VersionNT >= v6.1' evaluates to true. [35B0:2BA8][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleName' to value 'MicroStation CONNECT Edition SChinese-Language pack' [35B0:2BA8][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated' [35B0:2BA8][2020-07-30T12:12:42]i000: Loading managed bootstrapper application. [35B0:2BA8][2020-07-30T12:12:42]i000: Creating BA thread to run asynchronously. [35B0:0270][2020-07-30T12:12:42]i000: Setting Culture Info to zh-CN [35B0:0270][2020-07-30T12:12:42]i000: Setting string variable 'BeSelectedLanguage' to value 'zh-CN' [35B0:0270][2020-07-30T12:12:42]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value '' [35B0:0270][2020-07-30T12:12:42]i000: BentleyBundle Version 12.00.00.15 [35B0:0270][2020-07-30T12:12:42]i000: TRY Set TLS 1.2 [35B0:0270][2020-07-30T12:12:42]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Windows\Temp\{EF4096DA-2E38-4DF1-A2F1-E7080B021ABF}\.ba' [35B0:0270][2020-07-30T12:12:42]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Windows\Temp\{93BDDC41-0DED-473C-BC6D-E7C4C3A37022}\.cr' [35B0:0270][2020-07-30T12:12:42]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'D:\2020Y\03Bentley\MS\MS13\' [35B0:0270][2020-07-30T12:12:42]e000: Using Layout File : C:\Windows\Temp\{EF4096DA-2E38-4DF1-A2F1-E7080B021ABF}\.ba\Setup.lyt [35B0:0270][2020-07-30T12:12:42]e000: LoadTestAutomationApp(): Failed to load test dll with error 未将对象引用设置到对象的实例。 [35B0:0270][2020-07-30T12:12:42]i000: Running with UI [35B0:0270][2020-07-30T12:12:42]i000: Display is set to Full [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeLanguagePackUserControl.xaml [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml [35B0:0270][2020-07-30T12:12:42]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml [35B0:0270][2020-07-30T12:12:42]i000: Register callbak=ProxySettingsPage [35B0:0270][2020-07-30T12:12:42]i000: Display Page=ProxySettingsPage [35B0:0270][2020-07-30T12:12:42]i000: Cannot Display Page=ProxySettingsPage [35B0:2BA8][2020-07-30T12:12:42]i100: Detect begin, 6 packages [35B0:2BA8][2020-07-30T12:12:42]i000: KBDetectBegin: Current Image is not running from a Deployment Image. [35B0:2BA8][2020-07-30T12:12:42]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install [35B0:2BA8][2020-07-30T12:12:42]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check. [35B0:2BA8][2020-07-30T12:12:42]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1 [35B0:2BA8][2020-07-30T12:12:44]e000: WaitForProxyAuthentication: Waiting for proxy authentication [35B0:2BA8][2020-07-30T12:12:44]i000: Fetch BUDDI Key, RetryCount = 0 [35B0:2BA8][2020-07-30T12:12:44]e000: SetHeaders (): Added bootstrapper id in header, {50053503-8a4a-4b11-9fcd-743de76df506} [35B0:2BA8][2020-07-30T12:12:44]i000: Resolving Buddi Key. Attempt: 1 [35B0:2BA8][2020-07-30T12:12:46]i000: BeSkipKBCheck : [35B0:2BA8][2020-07-30T12:12:46]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [35B0:2BA8][2020-07-30T12:12:46]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [35B0:2BA8][2020-07-30T12:12:46]i000: DetectBegin: Installed State of Package DetectedAbsent [35B0:2BA8][2020-07-30T12:12:46]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.19.027' [35B0:2BA8][2020-07-30T12:12:46]i000: Trying per-machine extended info for property 'State' for product: {C829C29A-8099-326E-843E-B36AB0AAD6AA} [35B0:2BA8][2020-07-30T12:12:46]i000: Trying per-user extended info for property 'State' for product: {C829C29A-8099-326E-843E-B36AB0AAD6AA} [35B0:2BA8][2020-07-30T12:12:46]i000: Product or related product not found: {C829C29A-8099-326E-843E-B36AB0AAD6AA} [35B0:2BA8][2020-07-30T12:12:46]i000: Setting numeric variable 'DescartesProductState' to value 2 [35B0:2BA8][2020-07-30T12:12:46]i000: Trying per-machine extended info for property 'State' for product: {DFE7DC39-D885-3C0D-A869-1220DBD50CAE} [35B0:2BA8][2020-07-30T12:12:46]i000: Trying per-user extended info for property 'State' for product: {DFE7DC39-D885-3C0D-A869-1220DBD50CAE} [35B0:2BA8][2020-07-30T12:12:46]i000: Product or related product not found: {DFE7DC39-D885-3C0D-A869-1220DBD50CAE} [35B0:2BA8][2020-07-30T12:12:46]i000: Setting numeric variable 'VisualizationProductState' to value 2 [35B0:0270][2020-07-30T12:12:46]i000: ErrorPage Code: 0 [35B0:2BA8][2020-07-30T12:12:46]i102: Detected related bundle: {50e6b82d-9c01-454a-b958-30b7893301bd}, type: Dependent, scope: PerMachine, version: 10.13.1.1, operation: None [35B0:2BA8][2020-07-30T12:12:46]i000: Upgrading: RelatedOperation=None; RelationType=Dependent [35B0:2BA8][2020-07-30T12:12:46]i106: Calculating patch applicability for target product code: {90F60804-7000-11D3-8CFE-0150048383C9}, context: Machine [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: VisualBasicLang2, state: Present, cached: Complete [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: VisualBasicLangPackKB2803801_2, state: Present, cached: Complete [35B0:2BA8][2020-07-30T12:12:46]i105: Detected package: VisualBasicLangPackKB2803801_2 target: {90F60804-7000-11D3-8CFE-0150048383C9}, state: Present [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: LanguagePackInstaller, state: Absent, cached: None [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: VisualizationBundleModule_langpack, state: Absent, cached: None [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: DescartesBundleModule_langpack, state: Absent, cached: None [35B0:2BA8][2020-07-30T12:12:46]i101: Detected package: DgnIndexerLanguagePack, state: Present, cached: Complete [35B0:2BA8][2020-07-30T12:12:46]i000: Detect complete Start [35B0:2BA8][2020-07-30T12:12:46]i000: Setting string variable 'BePlannedAction' to value 'Install' [35B0:2BA8][2020-07-30T12:12:46]i000: LanguagePackInstaller AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: LanguagePackInstaller AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: LanguagePackInstaller AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualizationBundleModule_langpack AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: VisualizationBundleModule_langpack AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualizationBundleModule_langpack AnalyzeFeatureConditions: Condition=VisualizationProductState = 5, Action= [35B0:2BA8][2020-07-30T12:12:46]i052: Condition 'VisualizationProductState = 5' evaluates to false. [35B0:2BA8][2020-07-30T12:12:46]i000: VisualizationBundleModule_langpack AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: DescartesBundleModule_langpack AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: DescartesBundleModule_langpack AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: DescartesBundleModule_langpack AnalyzeFeatureConditions: Condition=DescartesProductState = 5, Action= [35B0:2BA8][2020-07-30T12:12:46]i052: Condition 'DescartesProductState = 5' evaluates to false. [35B0:2BA8][2020-07-30T12:12:46]i000: DescartesBundleModule_langpack AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLang2 AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLang2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLang2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: VisualBasicLangPackKB2803801_2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: DgnIndexerLanguagePack AnalyzeFeatureConditions: LaunchAction=Install [35B0:2BA8][2020-07-30T12:12:46]i000: DgnIndexerLanguagePack AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: DgnIndexerLanguagePack AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [35B0:2BA8][2020-07-30T12:12:46]i000: Detection complete planned action: Install [35B0:2BA8][2020-07-30T12:12:46]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle [35B0:2BA8][2020-07-30T12:12:46]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=True, IsPatch=False, IsWin64=True, Classification=, ServicePack=0 [35B0:2BA8][2020-07-30T12:12:46]i000: CheckForAddOnRelatedBundle (): RELATED {50e6b82d-9c01-454a-b958-30b7893301bd} Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0 [35B0:2BA8][2020-07-30T12:12:46]i000: GetUpgradeCodes (): ProviderKey={50e6b82d-9c01-454a-b958-30b7893301bd}, CodeType=BundleUpgradeCode [35B0:2BA8][2020-07-30T12:12:46]e000: CheckForAddOnRelatedBundle (): No product to AddOn found [35B0:2BA8][2020-07-30T12:12:46]e000: 在安装 MicroStation CONNECT Edition SChinese-Language pack 前,请先安装兼容的 MicroStation CONNECT Edition 版本 [35B0:2BA8][2020-07-30T12:12:46]i000: SessionMutex: Creating new SessionMutex [35B0:2BA8][2020-07-30T12:12:46]i000: SessionMutex: Creating Mutex with Name={50053503-8a4a-4b11-9fcd-743de76df506}-InstallMutex [35B0:2BA8][2020-07-30T12:12:46]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True [35B0:0270][2020-07-30T12:12:46]i000: ErrorPage Code: -1 [35B0:2BA8][2020-07-30T12:12:46]i000: WixInstallBA::SilentPlan [35B0:2BA8][2020-07-30T12:12:46]i000: [35B0:2BA8][2020-07-30T12:12:46]i000: Checking ADDLOCAL and REMOVE... [35B0:2BA8][2020-07-30T12:12:46]i199: Detect complete, result: 0x0
您好,版本不匹配,英文的版本比语言包 的更高,因此无法安装,需要卸载英文版UP13, 安装10130048版的英文程序,才可以安装这个中文包。或者可以直接用up14,up14也有中文的。
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/39555/modeling-and-visualization
我安装了新版的MS,请问新版的也没有中文帮助,是不是只有10和11才有中文帮助?
是的,help文档汉化比较耗时,不是每个版本都有的。
Answer Verified By: Bingle smith
