Connection client无法连接
edge和ie均设置了信任,也添加了证书,connect.bentley.com可以正常访问及登录
就是客户端和注册链接无法访问
更换过在其它电脑上可以正常登录的账号也是一样
请问,还有哪里需要设置吗?
  • 这台电脑是首次安装,相同安装包,在另一台电脑上一切正常。。
    status.benltey.com显示不安全,服务都显示正常,感觉证书导入失败了,还在测试其它导入证书的方法
  • 有台电脑新装程序,又出问题了 Connect Client无法连接,日志见下
    当前时间:“2022/1/24 0:48:44”
       在 System.IdentityModel.Tokens.SamlSecurityTokenHandler.ValidateToken(SecurityToken token)
       在 Bentley.STS.Client.Helpers.SSOHelper.DeserializeToken(String xmlSerializedToken, String realm, Action`1 logger)
       在 Bentley.STS.Client.WSFed_SSO.GetTokenFromXML(Action`1 logger, String xml)
    01-24-22 08:48:44.915 [1] DEBUG - LoginControlViewModel - Token is null!
    01-24-22 08:48:44.916 [1] ERROR - LoginControlViewModel - An error occured during federated login process - 未将对象引用设置到对象的实例。
    01-24-22 08:48:44.921 [1] DEBUG - LoginControlViewModel - OnTokenReceived
    01-24-22 08:48:44.921 [1] DEBUG - LoginControlViewModel - StatusVisibility=Visible
    01-24-22 08:48:44.921 [1] DEBUG - LoginControlViewModel - SSOControlVisibility=Collapsed
    01-24-22 08:48:44.921 [23] DEBUG - LoginControlViewModel - Logging in with credentials from STS login.
    01-24-22 08:48:44.921 [23] ERROR - Manager - No Token found to complete login process
    01-24-22 08:48:44.948 [1] DEBUG - LoginControlViewModel - Found security token
    01-24-22 08:48:44.948 [1] DEBUG - LoginControlViewModel - HTTP Decode token:<wst:RequestSecurityTokenResponseCollection xmlns:wst="http://docs.oasis-open.org/ws-sx/ws-trust/200512"><wst:RequestSecurityTokenResponse><wst:TokenType>http://docs.oasis-open.org/wss/oasis-wss-saml-token-profile-1.1#SAMLV1.1</wst:TokenType><wsp:AppliesTo xmlns:wsp="http://schemas.xmlsoap.org/ws/2004/09/policy"><wsa:EndpointReference xmlns:wsa="http://www.w3.org/2005/08/addressing"><wsa:Address>sso://wsfed_desktop/1805</wsa:Address></wsa:EndpointReference></wsp:AppliesTo><wst:RequestedSecurityToken><saml:Assertion MajorVersion="1" MinorVersion="1" AssertionID="BPQTR6oY8Q8z6WL_VR6gn49Rd3C" IssueInstant="2022-01-24T01:14:40.147Z" Issuer="https://ims.bentley.com/" xmlns:saml="urn:oasis:names:tc:SAML:1.0:assertion"><saml:Conditions NotBefore="2022-01-24T01:09:40.147Z" NotOnOrAfter="2022-01-31T01:14:40.147Z"><saml:AudienceRestrictionCondition><saml:Audience>sso://wsfed_desktop/1805</saml:Audience></saml:AudienceRestrictionCondition></saml:Conditions><saml:AuthenticationStatement AuthenticationInstant="2022-01-24T01:14:39.964Z" AuthenticationMethod="urn:oasis:names:tc:SAML:1.0:am:unspecified"><saml:Subject><saml:NameIdentifier Format="urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress">345ed3a5-304d-4bcf-9066-15297053873e</saml:NameIdentifier></saml:Subject></saml:AuthenticationStatement><saml:AttributeStatement><saml:Subject><saml:NameIdentifier Format="urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress">345ed3a5-304d-4bcf-9066-15297053873e</saml:NameIdentifier></saml:Subject><saml:Attribute AttributeName="becommunitiesusername" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>345ed3a5-304d-4bcf-9066-15297053873e</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="ultimatesite" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>1003313877</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="emailaddress" AttributeNamespace="http://schemas.xmlsoap.org/ws/2005/05/identity/claims"><saml:AttributeValue>xumingmin@zjgte.com.cn</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="entitlement" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>SELECT</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="nameidentifier" AttributeNamespace="http://schemas.xmlsoap.org/ws/2005/05/identity/claims"><saml:AttributeValue>345ed3a5-304d-4bcf-9066-15297053873e</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="usagecountryiso" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>HK</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="userid" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>345ed3a5-304d-4bcf-9066-15297053873e</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="organizationid" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>553f1a3d-840c-4644-b8c1-4fd6431e8b8e</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="countryiso" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>HK</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="isbentleyemployee" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>false</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="ismarketingprospect" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>false</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="givenname" AttributeNamespace="http://schemas.xmlsoap.org/ws/2005/05/identity/claims"><saml:AttributeValue>明忞</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="surname" AttributeNamespace="http://schemas.xmlsoap.org/ws/2005/05/identity/claims"><saml:AttributeValue>许</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="organization" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>Zhejiang Gas and Thermoelectricity Design</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="name" AttributeNamespace="http://schemas.xmlsoap.org/ws/2005/05/identity/claims"><saml:AttributeValue>xumingmin@zjgte.com.cn</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="has_select" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>true</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="ultimateid" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>9b68536d-01b0-4b33-9b84-ddde3d7db45c</saml:AttributeValue></saml:Attribute><saml:Attribute AttributeName="ultimatereferenceid" AttributeNamespace="http://schemas.bentley.com/ws/2011/03/identity/claims"><saml:AttributeValue>9b68536d-01b0-4b33-9b84-ddde3d7db45c</saml:AttributeValue></saml:Attribute></saml:AttributeStatement><ds:Signature xmlns:ds="http://www.w3.org/2000/09/xmldsig#"><ds:SignedInfo><ds:CanonicalizationMethod Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#"/><ds:SignatureMethod Algorithm="http://www.w3.org/2001/04/xmldsig-more#rsa-sha256"/><ds:Reference URI="#BPQTR6oY8Q8z6WL_VR6gn49Rd3C"><ds:Transforms><ds:Transform Algorithm="http://www.w3.org/2000/09/xmldsig#enveloped-signature"/><ds:Transform Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#"/></ds:Transforms><ds:DigestMethod Algorithm="http://www.w3.org/2001/04/xmlenc#sha256"/><ds:DigestValue>I2HK2BSrFmdSWMJTbleL4gJ75iAlSCpW8AecTHAbPJo=</ds:DigestValue></ds:Reference></ds:SignedInfo><ds:SignatureValue>J+6FYM8qapck9eond5SryYKdkxH8hNR9FzwrKnB7RYZF01cznRe+2JbhQAElNKx+IbZvetga1i0MBZ+34ZlTbSmfcCICN550XIcfapRakXFwjiGTZrNJ9Q3S360F8dgfuRl0nW8rzS/XQPqBnT9mkDsF4pQBsgKU49dIs/7VKixyK0buxldLciwCDkP2UBM15b/PfkUmOYZvSCVG+2tDn7zDobK1zPlE7KMYhqaE3bYZ/l59zm/cwasHKm7mvRNBNnkMAUO4Uf27F3aqbUPddaN2BOZdVHZvYS7AtpCd1cyQSFtL5xlMoAPT3qzG5d6GC05PS1X58i031FdwPDGKTA==</ds:SignatureValue><ds:KeyInfo><ds:X509Data><ds:X509Certificate>MIIG3zCCBcegAwIBAgIQAzsS1I0jf6iPFB6Ot8UrSTANBgkqhkiG9w0BAQsFADBPMQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMSkwJwYDVQQDEyBEaWdpQ2VydCBUTFMgUlNBIFNIQTI1NiAyMDIwIENBMTAeFw0yMTEwMjAwMDAwMDBaFw0yMjExMjAyMzU5NTlaMIGEMQswCQYDVQQGEwJVUzEVMBMGA1UECBMMUGVubnN5bHZhbmlhMQ4wDAYDVQQHEwVFeHRvbjEmMCQGA1UEChMdQmVudGxleSBTeXN0ZW1zLCBJbmNvcnBvcmF0ZWQxJjAkBgNVBAMTHWltcy10b2tlbi1zaWduaW5nLmJlbnRsZXkuY29tMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAuc41isCyH0Xf389eQDJ8NRQXRPiAKcyZwFhNw/3bbbRdW4DAzjxcUQV4ZbTMPwd1oR3dWWKaTgs5cbPj/aEWCS0h1GfQ/grvEVw09TRh2SEyAgSBc8DmA3m3t69EPMBAdrL9ytEIvuuXyCJ+RhWjn8RG6N/O5aRl1jiAAy2rDBwhR+olTY5euBi55IC7SYDmJKvBMoLokh+mcVmGpUx7Ox/EOSo0aKtAk0o53t9KYEFN0NKtlNChKpKpBgmaU6Csref9XguPxuWuAzNz9LcBfrVbgsJesImfTv5JD6JIcw+jHDTjqeqE1gsDh0QsiR06O8uNGMy3W3CyGdu48H32cwIDAQABo4IDfzCCA3swHwYDVR0jBBgwFoAUt2ui6qiqhIx56rTaD5iyxZV2ufQwHQYDVR0OBBYEFDml+zmsZD15TqYhjmQGkIw0cp+BMCgGA1UdEQQhMB+CHWltcy10b2tlbi1zaWduaW5nLmJlbnRsZXkuY29tMA4GA1UdDwEB/wQEAwIFoDAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwgY8GA1UdHwSBhzCBhDBAoD6gPIY6aHR0cDovL2NybDMuZGlnaWNlcnQuY29tL0RpZ2lDZXJ0VExTUlNBU0hBMjU2MjAyMENBMS00LmNybDBAoD6gPIY6aHR0cDovL2NybDQuZGlnaWNlcnQuY29tL0RpZ2lDZXJ0VExTUlNBU0hBMjU2MjAyMENBMS00LmNybDA+BgNVHSAENzA1MDMGBmeBDAECAjApMCcGCCsGAQUFBwIBFhtodHRwOi8vd3d3LmRpZ2ljZXJ0LmNvbS9DUFMwfwYIKwYBBQUHAQEEczBxMCQGCCsGAQUFBzABhhhodHRwOi8vb2NzcC5kaWdpY2VydC5jb20wSQYIKwYBBQUHMAKGPWh0dHA6Ly9jYWNlcnRzLmRpZ2ljZXJ0LmNvbS9EaWdpQ2VydFRMU1JTQVNIQTI1NjIwMjBDQTEtMS5jcnQwDAYDVR0TAQH/BAIwADCCAX0GCisGAQQB1nkCBAIEggFtBIIBaQFnAHYAKXm+8J45OSHwVnOfY6V35b5XfZxgCvj5TV0mXCVdx4QAAAF8nvfkHwAABAMARzBFAiEAygOkajkqTySYU/qYuXl0RXd5ppnuaGcowglH4xZJQBUCICNrtScqmFdub5XKIX2nR4k/2PNRtzS1+aUnf5CsTirPAHUAUaOw9f0BeZxWbbg3eI8MpHrMGyfL956IQpoN/tSLBeUAAAF8nvfkbgAABAMARjBEAiBZFQJiZvMHGvC1PHUnueHpXWeLs4cKL1thRR9pIirYugIgV7XAHT03y61W5QvCf3gFBgFSOPBP9CcqdgJjGeJhuX4AdgBByMqx3yJGShDGoToJQodeTjGLGwPr60vHaPCQYpYG9gAAAXye9+PzAAAEAwBHMEUCICFKioVODf5GIpsL+Aja6d+9iCuI9KqjI11f3ytgEflcAiEAvH2+CHDP9OqnhA/udXPcDLlb4JMWcTR155Ogy2jk4LcwDQYJKoZIhvcNAQELBQADggEBAFcUBhAFJKuR4qxXvNitUWLcP8v0+YRY668h5eIkGU4kyO+WlWCPizoWiaqng2KtZNPmMorxQy2YAsQ0qf6iCwtKKIEFskmAtdnUdAdsQTUoagSzifxi9/RRE8L8kKQpT7pxiyoDMDz/dunMWLQ5F12MG5YjZyiLo8eordAQ1mvJbPJvrxcn3800XhP6Eyo6eH1gu1xsgGkdVnVjUGSF6OX0NhSB4Y207BlC9Ah5ro9bS51XSc/02VXGaBJIzc1ET1a2ap4tN4rUtswTjN0NeFubCIFpcTJ6C4gtPw2f9uQjv+wnB+JlOHRdQrHounhEeh2hyXOGvadmiYRQEH/cmbg=</ds:X509Certificate></ds:X509Data></ds:KeyInfo></ds:Signature></saml:Assertion></wst:RequestedSecurityToken></wst:RequestSecurityTokenResponse></wst:RequestSecurityTokenResponseCollection>
    01-24-22 08:48:44.950 [1] DEBUG - LoginControlViewModel - Failed to deserialize token: System.IdentityModel.Tokens.SecurityTokenNotYetValidException: ID4222: 拒绝了 SamlSecurityToken,因为不满足 SamlAssertion.NotBefore 条件。
    NotBefore:“2022/1/24 1:09:40”
    01-24-22 08:48:44.950 [1] DEBUG - LoginControlViewModel - Token is null!
    01-24-22 08:48:44.950 [1] ERROR - LoginControlViewModel - An error occured during federated login process - 未将对象引用设置到对象的实例。
    01-24-22 08:48:44.985 [1] WARN  - App - Error changing icons - 调用线程无法访问此对象,因为另一个线程拥有该对象。
  • 您好,倒数第二行提示Federation 登录失败,您单位使用了联合帐号技术吗?联合帐号需要跟Bentley额外申请,而且需要Bentley这边给额外配置,貌似国内还没有单位用联合帐号的。
