//ElmentHandler eh;(参数化单元)
FindInstancesScopePtr scope = FindInstancesScope::CreateScope(eh, FindInstancesScopeOption(DgnECHostType::All)); ECQueryPtr query = ECQuery::CreateQuery(ECQUERY_PROCESS_SearchAllClasses); DgnECInstanceIterable iterable = Bentley::DgnPlatform::DgnECManager::GetManager().FindInstances(*scope, *query); for (DgnECInstanceIterable::const_iterator it = iterable.begin(); it != iterable.end(); ++it) { DgnECInstancePtr instance = *it; ECN::ECClassCR instanceClass = instance->GetClass(); WString classDisplayName = instanceClass.GetDisplayLabel();
ECPropertyIterable properties = instanceClass.GetProperties(); for (ECPropertyIterable::const_iterator it = properties.begin(); it != properties.end(); ++it) { ECValue v; ECPropertyCP pProp = (*it); if (pProp->GetName().find(L"ParameterValuesContainer")) continue;
ECValue v1;
WCharCP propertyAccessString = pProp->GetName().c_str(); ECObjectsStatus status = instance->GetValue(v1, propertyAccessString, 0); if (ECOBJECTS_STATUS_Success != status) continue;
现在我能获取ECValue v1,调试看到其如下形式:
看了下帮助文档没发现读取struct里面的值的函数,希望得到大家的帮助!
DgnECInstance下的WriteChanges函数。
我用了好像还是改不了。
void changeParametricCell(EditElementHandleCR eeh) { FindInstancesScopePtr scope = FindInstancesScope::CreateScope(eeh, FindInstancesScopeOption(DgnECHostType::All)); ECQueryPtr query = ECQuery::CreateQuery(ECQUERY_PROCESS_SearchAllClasses); DgnECInstanceIterable iterable = Bentley::DgnPlatform::DgnECManager::GetManager().FindInstances(*scope, *query); DgnECInstancePtr instance = *(++(iterable.begin())); WString filename; ECN::ECClassCR instanceClass = instance->GetClass(); ECPropertyIterable properties = instanceClass.GetProperties(); for (ECPropertyIterable::const_iterator it0 = properties.begin(); it0 != properties.end(); ++it0) { ECValue v; ECPropertyCP pProp = (*it0); if (pProp->GetName().Equals(L"ParameterValuesContainer")) { if (pProp->GetIsArray()) { ArrayECPropertyCP aep = pProp->GetAsArrayProperty(); ECN::ECClassCP _instanceClass = aep->GetStructElementType(); ECPropertyIterable _properties = _instanceClass->GetProperties(false); //获取数组个数 instance->GetValue(v, pProp->GetName().data()); ArrayInfo ai = v.GetArrayInfo(); int count = ai.GetCount(); for (int index = 0; index < count; index++) { instance->GetValue(v, pProp->GetName().data(), index); IECInstancePtr _intance = v.GetStruct(); for (ECPropertyIterable::const_iterator it1 = _properties.begin(); it1 != _properties.end(); ++it1) { if ((*it1)->GetName().Equals(L"Adhoc_Label") || (*it1)->GetName().Equals(L"Adhoc_Value") || (*it1)->GetName().Equals(L"Adhoc_Type")) { ECValue _v; _intance->GetValue(_v, (*it1)->GetName().data()); if (wcscmp(_v.GetString(), L"网格长") == 0) { ECValue value1(L"1.23"); _intance->SetValue(L"Adhoc_Value", value1); // _intance->ChangeValue(L"Adhoc_Value", value1); break; } } } } } } } filename.Sprintf(L"D:\\1.xml"); instance->WriteToXmlFile(filename.data(), true, true); instance->WriteChanges(); } void changeParametricCell0(EditElementHandleCR eeh) { FindInstancesScopePtr scope = FindInstancesScope::CreateScope(eeh, FindInstancesScopeOption(DgnECHostType::All)); ECQueryPtr query = ECQuery::CreateQuery(ECQUERY_PROCESS_SearchAllClasses); DgnECInstanceIterable iterable = Bentley::DgnPlatform::DgnECManager::GetManager().FindInstances(*scope, *query); DgnECInstancePtr instance = *(++(iterable.begin())); WString filename; ECN::ECClassCR instanceClass = instance->GetClass(); ECPropertyIterable properties = instanceClass.GetProperties(); filename.Sprintf(L"D:\\2.xml"); instance->WriteToXmlFile(filename.data(), true, true); } ParametricCellHandler& pcHandler = ParametricCellHandler::GetInstance(); EditElementHandle eeh; if (ParameterStatus::Success != pcHandler.CreateCellElement(eeh, *pcInfo)) return; changeParametricCell(eeh); changeParametricCell0(eeh); eeh.AddToModel();
我用instance->ScheduleWriteChanges(eeh);可以保存在模型上了,但是好像参数类型不对,我写进去的Adhoc_Value的类型是字符串,但是它实际的类型是double类型的,我写进去好像只是单纯的显示文本变了,里面的double值没变,模型的参数值虽然是1m,但是实际还是4m。而且修改后的那个参数我在CE上直接手动修改并没有应用到模型上,好像失效了。
你先用Mstn自带的参数化单元试试(C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets\MetroStation\DGN\Parametric Models\Double Door Cabinet.dgn),修改参数成功了再用你自己的 参数化单元。
好了 谢谢老师,我刚刚换了个参数化单元好了,是我参数化单元的问题
