[MSCE C#] 如何在WPF或者在WINFORM中显示一个microstation cell的三维几何图形?
 类似这种效果
  • 1. 将如下代码保存为MyElementPreviewControl.cs
    using System;
    using System.Drawing;
    using System.Runtime.InteropServices;
    using Bentley.GeometryNET;
    using Bentley.DgnPlatformNET;
    using Bentley.DgnPlatformNET.Elements;
    using Bentley.MstnPlatformNET.WinForms.Controls;
    using System.Windows.Forms;
    namespace MSAppNET
        public class MyElementPreviewControl : ElementPreview
            private DisplayableElement m_elem;
            private MSRenderMode m_renderMode;
            public MyElementPreviewControl(ref DisplayableElement elem, MSRenderMode renderMode)
                m_elem = elem;
                m_renderMode = renderMode;
            protected override void OnPaint(PaintEventArgs e)
                base.OnPaint(e);
                ViewFlags myViewFlags = ViewInformation.GetDefaultFlags();
                myViewFlags.Camera = false;
                myViewFlags.RenderMode = (int)m_renderMode;
                myViewFlags.Grid = false;
                DRange3d elemRng;
                m_elem.CalcElementRange(out elemRng);
                DPoint3d myOrg = elemRng.Low;
                DPoint3d myRng = DPoint3d.Subtract(elemRng.High, elemRng.Low);
                Rectangle myRect = new Rectangle(Location, Size);
                DisplayElemHandle(BytesToIntptr(m_elem.ElementHandle), myViewFlags, myRect, null, myOrg, myRng);
            public static IntPtr BytesToIntptr(byte[] bytes)
                int size = bytes.Length;
                IntPtr buffer = Marshal.AllocHGlobal(size);
                Marshal.Copy(bytes, 0, buffer, size);
                return buffer;
    2. 在你的Winform中添加一个Panel控件;
    3. 在你的WinForm.cs中大致如下写:
    public partial class MstnControlsForm : //Bentley.MstnPlatformNET.WinForms.Adapter
                                                System.Windows.Forms.Form
            private MyElementPreviewControl myElemPreview;
            public MstnControlsForm()
                InitializeComponent();
                DgnModel dgnModel = Session.Instance.GetActiveDgnModel();
                DPoint3d[] pts = { new DPoint3d(0, 0, 0), new DPoint3d(1000, 1000,0),
                                   new DPoint3d(2000, -1000,0), new DPoint3d(3000, 0, 0)};
                DVector3d sTangent = DVector3d.FromXY(1000, 1000);
                DVector3d eTangent = DVector3d.FromXY(2000 - 3000, -1000);
                MSBsplineCurve curve = MSBsplineCurve.CreateFromInterpolatePoints(pts, 3, true, ref sTangent, ref eTangent, true, 3);
                DisplayableElement myElem = new BSplineCurveElement(dgnModel, null, curve);
                //DisplayableElement myElem = dgnModel.FindElementById((ElementId)6645L) as DisplayableElement;
                if (null == myElem)
                    MessageCenter.Instance.ShowErrorMessage("myElem is invalid", null, true);
                    return;
                myElemPreview = new MyElementPreviewControl(ref myElem, MSRenderMode.Wireframe);
                myElemPreview.Dock = DockStyle.Fill;
                this.panel1.Controls.Add(myElemPreview);
    4. 当然,我这里是在代码中临时创建的一个元素,你可以将Cell读入到元素中带入即可。
    5. MyElementPreviewControl仅仅演示了TopView的显示情况,你可以改造传入合适的RotMatrix。
    Answer Verified By: 鑫 杨
  • 符老师,您好,我在使用您的样例代码时,程序偶尔会莫名抛异常(多数情况下功能可以正常实现),是否ElemPreviewContrel的实例需要进行某些释放操作,我在插件中进行了频繁清空panel,然后add新的ElemPreviewContrel实例的操作,是否这样的操作造成了异常?
    我的dispalyElem来自于已addToModel的cell,是否需要对不在使用的dispalyElem进行某些释放操作。
    谢谢老师
  • 为何要“频繁清空panel,然后add新的ElemPreviewContrel实例”?保持同一个Panel,只需要改变Element往同一个Panel上显示即可。
