ElementPropertiesSetter elePropSet = new ElementPropertiesSetter(); RgbColorDef rgbColor = new RgbColorDef((byte)AutoDimFormatInfo.rgbline.R, (byte)AutoDimFormatInfo.rgbline.G, (byte)AutoDimFormatInfo.rgbline.B); uint colormap = DgnColorMap.CreateElementColor(rgbColor, null, null, dgnfile); elePropSet.SetColor(colormap); for (int i = 0; i < listline.Count; i++) { elePropSet.Apply(listline[i]); headcellElement.ReplaceInModel(headcellElement);//报错 //headcellElement.ReplaceInModel(listline[i]);//报错 }
您好老师,我修改完cell的子元素,ReplaceInModel其中的cell元素仍然会报错,其他代码没有问题,请问老师能否提供下案例代码怎么修改cell子元素呢?
你如果仅仅是修改Cell的颜色的话,我测试了不需要遍历到Cell中的每个子元素呀。如下代码可以:
public static void ChangeCellProp(string unparsed) { DgnModel myModel = Session.Instance.GetActiveDgnModel(); CellHeaderElement myCell = myModel.FindElementById((ElementId)3288L) as CellHeaderElement; Element oldCell = Element.GetFromElementRef(myCell.GetNativeElementRef()); ElementPropertiesSetter setter = new ElementPropertiesSetter(); setter.SetColor(3); setter.Apply(myCell); myCell.ReplaceInModel(oldCell); }
您好 符老师,我这边的需求是分别去修改Cell中的子元素,例如:有字体,有直线(线串),分别修改字体的颜色,字体样式,直线的颜色,线性之类的。通过ElementPropertySetter修改,修改完之后想通过ReplaceInModel刷新Cell元素,然后就出错了。
有可能是.NET封装的问题。用C#写的如下代码确实会导致Mstn崩溃:
public static void ChangeCellProp(string unparsed) { DgnModel myModel = Session.Instance.GetActiveDgnModel(); CellHeaderElement myCell = myModel.FindElementById((ElementId)3288L) as CellHeaderElement; Element oldCell = Element.GetFromElementRef(myCell.GetNativeElementRef()); ElementPropertiesSetter setter = new ElementPropertiesSetter(); ChildElementEnumerator children = new ChildElementEnumerator(myCell); while (children.MoveNext()) { switch (children.Current.ElementType) { case MSElementType.Shape: setter.SetColor(3); setter.Apply(children.Current); break; case MSElementType.LineString: setter.SetColor(4); setter.Apply(children.Current); break; default: break; } } myCell.ReplaceInModel(oldCell); }
但如下C++代码就能正确工作:
void changeCellProp() { EditElementHandle myCell(3288L, ACTIVEMODEL); ElementRefP oldRef = myCell.GetElementRef(); ElementPropertiesSetterPtr setter = ElementPropertiesSetter::Create(); for (ChildEditElemIter child(myCell); child.IsValid(); child = child.ToNext()) { switch (child.GetElementType()) { case SHAPE_ELM: setter->SetColor(3); setter->Apply(child); break; case LINE_STRING_ELM: setter->SetColor(4); setter->Apply(child); break; default: break; } } myCell.ReplaceInModel(oldRef); }
Answer Verified By: Shaopu.Cao
好的,谢谢符老师,
我通过如下方法解决了,
参考自:https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/132050/connect-up-4-net-api-modify-delete-cell-subelement
如下贴部分代码(参考思路是这样的),el为子元素:
private List<Element> listEle = new List<Element>(); ElementPropertiesSetter elePropSet = new ElementPropertiesSetter(); RgbColorDef rgbColor = new RgbColorDef((byte)AutoDimFormatInfo.rgbline.R, (byte)AutoDimFormatInfo.rgbline.G, (byte)AutoDimFormatInfo.rgbline.B); uint colormap = DgnColorMap.CreateElementColor(rgbColor, null, null, dgnfile); elePropSet.SetColor(colormap); elePropSet.Apply(el); listEle.Add(el); DPoint3d origin; headcellElement.GetTransformOrigin(out origin); CellHeaderElement newCell = new CellHeaderElement(dgnmodel, "AutoWaterLevel", origin, DMatrix3d.Identity, listEle); newCell.ReplaceInModel(headcellElement); listEle.Clear();
感谢分享。
不过这种方法对于单元头中含有自己属性的情况将会丢失。另外,还要调用GetBasicTransform得到变换矩阵传到你新建的newCell中的第四个参数为好,这样能保证单元的缩放比例和旋转方向。
