我看了这个函数的实现,只是在不同窗口之间进行client, screen之间的转换,没有
因为ribbon还有minimize状态,所以最好用mdlWindow_globalPointConversionIncrease 进行转换
// note: you can use the following corrected code piece to get pure windows screen point for the button event.
// both pointInMDLclient and globlePoint are in a window coordinates which is relative to a window rect.
// as you said, Viewport::ViewToScreen don't return screen point in fact.
// please focus on the using of mdlWindow_globalPointConversionIncrease which is the key point here.
// other changes just rename the variable names to make it's meaning more accurate.
// ev.GetViewPoint returns the mouse position of client area of the view window,
// Viewport::ViewToScreen returns the point which is relative to left-up corner of a special client window which
// is the gray area to contain the 8 view windows. The special client window is like the Win32
// MDClient for multi-document program, and we also call it usable area
DPoint3d pointInMDLclient3D = { 0 };
ev.GetViewport ()->ViewToScreen (&pointInMDLclient3D, ev.GetViewPoint (), 1);
Point2d pointInMDLclient = { (int)pointInMDLclient3D.x, (int)pointInMDLclient3D.y };
// in CE, because there is ribbon bar, we must convert the pointInMDLclient to global point which is relative to
// the left-up conner of the main frame window.
Point2d globlePoint = { 0 };
MSDialogP viewWindow = mdlWindow_viewWindowGet (ev.GetViewNum ());
if (mdlWindow_isGlobalPointConversionRequired (viewWindow->GetScreenNumber ()))
mdlWindow_globalPointConversionIncrease (&globlePoint, viewWindow, &pointInMDLclient);
else
globlePoint = pointInMDLclient;
// now use mdlWindow_globalPointToScreen to convert the global point to screen point which is pure windows concept
// but not the Microstation concept, and I don't think there is equivalent C++ method in DgnButtonEvent or other class
Point2d screenPt2d = { 0 };
mdlWindow_globalPointToScreen (&screenPt2d, mdlWindow_viewWindowGet (ev.GetViewNum ()), &globlePoint);
这里你最终需要的是globlePoint而不是screenPt2d。 我是直接粘过来了另外一个帖子, 他想得到screen(monitor) point
C#里面怎么把第二个参数传到mdlWindow_globalPointConversionIncrease中去呢?
