从论坛上找到这段代码:
DgnDocumentMoniker moniker = DgnDocumentMoniker.CreateFromFileName(@"H:\XX\XXX\Model.dgn", null);DgnAttachment att = dgnModel.CreateDgnAttachment(moniker, "2D Metric Design");if (att != null){ att.NestDepth = 99; att.SetMasterOrigin(setPoint); att.WriteToModel(true);}
这段代码用来添加参考文件,如果我想参考文件中已有的view里边的Named Boundaries的视图该如何改写呢?
利用NamedBoundaryies 的边界,创建一个Saved View.
在引用时可以应用Saved View(NamedView)
if ( !string.IsNullOrEmpty(applyNamedView) )
ModelId fromModelId = fromDgnFile.FindModelIdByName(fromModelName);
DgnModel fromModel = fromDgnFile.LoadRootModelById(out status, fromModelId, true, true, true);
//应用SavedView
status = att.ApplyNamedView(applyNamedView, 1, 1, new ApplyViewClipOptions(), true, StandardView.Top);
//设置参考坐标与源模型相同
NamedViewCollection nvc = fromModel.GetDgnFile().GetNamedViews();
NamedView nv = nvc.FindByName(applyNamedView, false);
ViewInformation viewInfo = nv.GetViewInfo();
DPoint3d dpOff = new DPoint3d(viewInfo.Delta.X / 2.0, viewInfo.Delta.Y / 2.0, 0);
att.SetMasterOrigin(viewInfo.Origin + dpOff);
可以应用SavedView来实现,如果你已经有NamedBoundaries,可以用它的边界先创建一个SavedView,然后再应用SavedView
if ( !string.IsNullOrEmpty(applyNamedView) ) { ModelId fromModelId = fromDgnFile.FindModelIdByName(fromModelName); DgnModel fromModel = fromDgnFile.LoadRootModelById(out status, fromModelId, true, true, true); //应用SavedView status = ref1.ApplyNamedView(applyNamedView, 1, 1, new ApplyViewClipOptions(), true, StandardView.Top); //设置参考坐标与源模型相同 NamedViewCollection nvc = fromModel.GetDgnFile().GetNamedViews(); NamedView nv = nvc.FindByName(applyNamedView, false); ViewInformation viewInfo = nv.GetViewInfo(); DPoint3d dpOff = new DPoint3d(viewInfo.Delta.X / 2.0, viewInfo.Delta.Y / 2.0, 0); ref1.SetMasterOrigin(viewInfo.Origin + dpOff); }
Answer Verified By: F T
试试这段代码,NavedView就是界面中的SavedView
郭老师:再请教一下通过NamedBoundaries创建一个SavedView的方法。
