如题,请问如何获取MS里面一个立方体的拓扑结构信息?
我再MS CE版本的开发文档里面看到,关于实体元素,ISolidKernelEntity represents a boundary representation body (BRep).
如下:
我想请问,如何获取拓扑关系?“”The topology is the faces, edges, and vertices that describe how the geometry is connected.“”
我试过
并没有找到哪里有拓扑关系的描述?
求指教~谢谢~~~
你在MS SDK目录下的PSolidCoreAPI.h中的struct TopologyID结构体,可以找到相关信息。
感谢,找到了一些拓扑信息;
请问有没有样例代码供参考?我之前没有写过Solid相关的代码。在SDK的example中没有找到TopologyID相关的内容。
谢谢~~
Work smart, not just work hard!
UInt32 highestNodeId;
UInt32 lowestNodeId;
BentleyStatus status = SolidUtil::TopologyID::FindNodeIdRange(*srcSolid, highestNodeId, lowestNodeId);
if (SUCCESS == status)
WPrintfString wStr(L"highestNodeId = %ld, lowestNodeId = %ld", highestNodeId, lowestNodeId);
mdlDialog_dmsgsPrint(wStr.GetWCharCP());
UInt32 nodeId = 33;
bool overrideExisting = false;
status = SolidUtil::TopologyID::AddNodeIdAttributes(*srcSolid, nodeId, overrideExisting);
| SolidUtil::TopologyID::FindNodeIdRange Xiaoqi.Zhang
WPrintfString wStr(L"After DeleteNodeIdAttributes, the highestNodeId = %ld, lowestNodeId = %ld", highestNodeId, lowestNodeId);
| SolidUtil::TopologyID::IncrementNodeIdAttributes Xiaoqi.Zhang
case eIncrementNodeIdAttributes:
//! Increment the topology ids for all faces of the given body. Used to avoid nodeId conflicts between target and tool bodies.
//! @param[in,out] entity The body to modify.
//! @param[in] increment The topology node id in each nodeId-entityId pair will be incremented by this amount.
//! @return SUCCESS if ids could be incremented.
//PSOLIDCORE_EXPORT static BentleyStatus IncrementNodeIdAttributes(ISolidKernelEntityR entity, Int32 increment);
Int32 increment = 100;
BentleyStatus status = SolidUtil::TopologyID::IncrementNodeIdAttributes(*srcSolid, increment);
WPrintfString wStr(L"After IncrementNodeIdAttributes, the highestNodeId = %ld, lowestNodeId = %ld", highestNodeId, lowestNodeId);
return true;
break;
| SolidUtil::TopologyID::DeleteNodeIdAttributes Xiaoqi.Zhang
case eDeleteNodeIdAttributes:
//! Remove the topology ids from all faces of the given body.
//! @return SUCCESS if ids could be removed.
//PSOLIDCORE_EXPORT static BentleyStatus DeleteNodeIdAttributes(ISolidKernelEntityR entity);
BentleyStatus status = SolidUtil::TopologyID::DeleteNodeIdAttributes(*srcSolid);
case eAddNodeIdAttributes:
//! Assign new topology ids to faces of the given body. Resolves duplicate face ids such as from a face being split.
//! @param[in] nodeId The topology node id to use in the new nodeId-entityId pairs.
//! @param[in] overrideExisting false to assign new ids only to currently un-assigned faces and true to replace all existing ids.
//! @return SUCCESS if ids could be added.
//PSOLIDCORE_EXPORT static BentleyStatus AddNodeIdAttributes(ISolidKernelEntityR entity, UInt32 nodeId, bool overrideExisting);
UInt32 nodeId = 22;
bool overrideExisting = true;
| SolidUtil::TopologyID::AddNodeIdAttributes Xiaoqi.Zhang
BentleyStatus status = SolidUtil::TopologyID::AddNodeIdAttributes(*srcSolid, nodeId, overrideExisting);
老师,您举的几个例子都是使用ISolidKernelEntityR 类的。
我想测试一下IdFromFace (FaceId &faceId, ISubEntityCR subEntity, bool useHighestId)等几个用ISubEntityCR的方法。。。。
ISolidKernelEntityR到ISubEntityCR怎么转换?或者EditElementHandle到ISubEntityCR怎么转换?
